bott0r
November 25, 2018, 10:16pm
1
Hello Everyone,
I am struggling to get my alarm clock to work again. Ever since i updated to 82.1 the automation doesnt work anymore and i cannot figure out why.
Any pointers would be helpful.
input_number:
alarm_1_hour:
icon: mdi:timer
initial: 7
min: 0
max: 23
step: 1
alarm_1_minutes:
icon: mdi:timer
initial: 0
min: 0
max: 59
step: 1
alarm_1_offset:
icon: mdi:blur-linear
initial: 15
min: 0
max: 60
step: 15
input_boolean:
alarm_1_weekday:
initial: on
icon: mdi:calendar
alarm_1_weekend:
initial: off
icon: mdi:calendar
friendly_name: sensor.alarm_1_time
sensors:
alarm_1_time:
friendly_name: 'Alarm Time'
value_template: >-
{{ "%0.02d:%0.02d" | format(states("input_number.alarm_1_hour") | int, states("input_number.alarm_1_minutes") | int) }}
entity_id: sensor.alarm_1_time_minus_offset
sensors:
alarm_1_time_minus_offset:
friendly_name: 'Offset Time'
value_template: >-
{{ '%0.02d:%0.02d' | format( ((((states('input_number.alarm_1_hour') | int)*60 + (states('input_number.alarm_1_minutes') | int) - (states('input_number.alarm_1_offset'))| int)/60)| int),(((((((((states('input_number.alarm_1_hour') | int)*60 + (states('input_number.alarm_1_minutes') | int) - (states('input_number.alarm_1_offset')) | int)/60)) - ((((states('input_number.alarm_1_hour') | int)*60 + (states('input_number.alarm_1_minutes') | int) - (states('input_number.alarm_1_offset')) | int)/60)| int))*100) | int)*60/100) | round) ) }}
group:
alarm_1:
name: Wake Me Up
entities:
- sensor.time
- sensor.alarm_1_time
- sensor.alarm_1_time_minus_offset
- input_number.alarm_1_hour
- input_number.alarm_1_minutes
- input_number.alarm_1_offset
- input_boolean.alarm_1_weekday
- input_boolean.alarm_1_weekend
automation:
- id: alarm_1_weekday
alias: 'Wake me up (weekday)'
- platform: time
minutes: '/1'
seconds: 00
condition:
condition: and
conditions:
- condition: state
entity_id: input_boolean.alarm_1_weekday
state: 'on'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- condition: template
value_template: "{{ states.sensor.time.state == states.sensor.alarm_1_time_minus_offset.state }}"
- data:
message: Alarm ! Current time is {{ states.sensor.time.state }} and alarm is set to {{ states.sensor.alarm_1_time.state }} with an offset of {{ states.input_number.alarm_1_offset.state }} set to {{ states.sensor.alarm_1_time_minus_offset.state }} Weekdays ({{ states.input_boolean.alarm_1_weekday.state }} ) and Weekends ({{ states.input_boolean.alarm_1_weekend.state }} ) test {{ "%0.02d:%0.02d" | format(states("input_number.alarm_1_hour") | int, states("input_number.alarm_1_minutes") | int) }}
service: notify.zchat
- data: {}
service: script.wakeup_sequence
- id: alarm_1_weekend
alias: 'Wake me up (weekend)'
- platform: time
minutes: '/1'
seconds: 00
condition:
condition: and
conditions:
- condition: state
entity_id: input_boolean.alarm_1_weekend
state: 'on'
- condition: time
weekday:
- sat
- sun
- data:
- data: {}
nickrout
(Nick Rout)
November 26, 2018, 6:24am
2
“Does not work” is not an error report.
bott0r
November 26, 2018, 6:36am
3
The Bug is: It does not trigger the automation.
There is no log that I could post, not really sure what to say.
nickrout
(Nick Rout)
November 26, 2018, 6:58am
4
Take the “and” out of your conditions. They are not necessary, and they seem to be creating problems in recent versions of HA.
bott0r
November 26, 2018, 7:54am
5
I changed the automation to this. The automation is still not triggered, i tried to just take the and away but then i’ll get a config error.
automation:
- platform: time
minutes: '/1'
seconds: 00
condition:
- condition: state
state: 'on'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- data:
- data: {}
bott0r
November 26, 2018, 9:46am
6
I shortened it to and its still not working, I tested the states and sensors they are working properly, in the interface, and the condition seems easy enough to write.
automation:
- platform: time
minutes: '/1'
seconds: 00
condition:
- data:
message: Alarm !
Put quotes around the message.
Does it trigger manually?
Any errors?
bott0r
November 26, 2018, 10:44am
8
Thanks for the hint, I tried triggering the automation by hand and the message delivers without a problem
i even put all the states in to check if everything is captured properly
I guess it must be condition or trigger issue, is there another way to go about the time trigger?
bott0r
November 26, 2018, 11:04am
9
I guess I found the error. Automations cannot be included into packages but must be contained in the automation.yml
cheers thanks for the help
Thats kind of a bummer; I like being able to load everything related to a package (scripts, groups, automations, etc) from that package file. Makes it a little more organized IMO and easier to share.
I went back and looked at the packages documentation here: https://www.home-assistant.io/docs/configuration/packages/ and it says
“The package configuration can include: switch , light , automation , groups , or most other Home Assistant components including hardware platforms. It can be specified inline or in a separate YAML file using !include .”
So is that out of date or I was correct to include my automation within my package and there’s something else causing the problem.
bott0r
January 20, 2019, 2:56pm
12
I will give it a try, when I come home again maybe it was bugged for a version or two.
Automations work fine in packages, and always have.
bott0r
January 28, 2019, 1:13pm
15
Works now for me in packages:
input_number:
alarm_1_hour:
icon: mdi:timer
initial: 7
min: 0
max: 23
step: 1
alarm_1_minutes:
icon: mdi:timer
initial: 0
min: 0
max: 59
step: 1
alarm_1_offset:
initial: 15
min: 0
max: 60
step: 15
input_boolean:
alarm_1_weekday:
initial: on
icon: mdi:calendar
alarm_1_weekend:
initial: off
icon: mdi:calendar
sensors:
alarm_1_time:
value_template: >-
sensors:
value_template: >-
group:
alarm_1:
name: Wake Me Up
entities:
- sensor.time
automation:
- id: 'alarm_1_weekday'
alias: Wake me up (weekday)
- platform: time_pattern
minutes: /1
seconds: 0
condition:
- condition: state
state: 'on'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
value_template: '{{ states.sensor.time.state == states.sensor.alarm_1_time_minus_offset.state }}'
#- data:
# message: Alarm ! Current time is {{ states.sensor.time.state }} and alarm is set to {{ states.sensor.alarm_1_time.state }} with an offset of {{ states.input_number.alarm_1_offset.state }} set to {{ states.sensor.alarm_1_time_minus_offset.state }} Weekdays ({{ states.input_boolean.alarm_1_weekday.state }} ) and Weekends ({{ states.input_boolean.alarm_1_weekend.state }} ) test {{ "%0.02d:%0.02d" | format(states("input_number.alarm_1_hour") | int, states("input_number.alarm_1_minutes") | int) }}
# service: notify.zchat
- data: {}
- id: 'alarm_1_weekend'
alias: Wake me up (weekend)
minutes: /1
seconds: 0
condition:
- condition: state
state: 'on'
- condition: time
weekday:
- sat
- sun
#- data:
- data: {}
script:
'wakeup_dim':
alias: wakeup_dim
sequence:
- data:
brightness: '0'
entity_id:
- light.lamp_kitchen1
- light.lamp_kitchen2
- light.lamp_kitchen3
- light.lamp_dinning1
- light.lamp_dinning2
- light.lamp_dinning3
- light.office_lamp_new
- light.lamp_couch
- light.bedroom_lamp1
- light.bedroom_lamp2
- light.hallway_lamp_new
kelvin: '2200'
transition: '0'
service: light.turn_on
- data:
brightness: '0'
entity_id:
- light.gateway_light_286c07fa2642
- light.yeelight_rgb_34ce008d0d2f
rgb_color:
- 255
- 169
- 92
- data:
brightness_pct: '0'
entity_id:
- light.colour_bulb
rgb_color:
- 255
- 169
- 92
transition: '0'
'wakeup_bright':
alias: wakeup_bright
sequence:
- data_template:
brightness: '255'
kelvin: '2700'
transition: '{{(states(''input_number.alarm_1_offset'') | int ) *60}}'
entity_id:
- light.lamp_couch
- data_template:
brightness: '255'
entity_id:
- light.colour_bulb
rgb_color:
- 255
- 169
- 92
'wakeup_sequence':
alias: wakeup_sequence
sequence:
- data:
message: Alarm ! Current time is {{ states.sensor.time.state }} and alarm is set to {{ states.sensor.alarm_1_time.state }} with an offset of {{ states.input_number.alarm_1_offset.state }} set to {{ states.sensor.alarm_1_time_minus_offset.state }} Weekdays ({{ states.input_boolean.alarm_1_weekday.state }} ) and Weekends ({{ states.input_boolean.alarm_1_weekend.state }} ) 00:{{ states.input_number.alarm_1_offset.state | int }}:00
- data: {}
service: script.wakeup_dim
- delay: 00:00:02
- service: script.wakeup_bright
- delay: '00:{{ states.input_number.alarm_1_offset.state | int }}:00'
- data: {}
service: script.play_wakeup_music
