I’m trying to get an Abode alarm trigger setup to arm my Blink cameras and send me a push notification when the Abode alarm system is armed to home or away.
Things I’ve referenced trying to get this to work:
- Abode integration documentation
- Need Assistance with Trigger - Configuration - Home Assistant Community (home-assistant.io)
- Help with abode alarm triggering automation - Configuration - Home Assistant Community (home-assistant.io)
note: I randomized the device_id
below.
I have a working setup for when Abode is Disarmed:
alias: Abode Disarmed - Disarm Blink Cameras
description: ''
- platform: device
device_id: 7c89db22d86d93f09159590465bd25d4
domain: alarm_control_panel
entity_id: alarm_control_panel.abode_alarm
type: disarmed
condition: []
- service: alarm_control_panel.alarm_disarm
data: {}
entity_id: alarm_control_panel.blink_home
- service: notify.mobile_app_iphone
title: Abode HA Automation
message: Blink Cameras DISARMED because Abode was set to Standby
mode: queued
max: 10
However I can’t get the trigger to work for when Abode is set to Away or Home (and thus armed).
- I’ve tried with events and devices as triggers, with many different triggers, and with only one of these triggers at a time (home, away, arming).
- When manually executed this does run and arm my Blink cameras and send me a push notification properly.
alias: Abode Armed - Arm Blink Cameras
description: ''
- platform: device
type: armed_home
- platform: device
type: armed_away
- platform: device
type: arming
condition: []
- service: alarm_control_panel.alarm_arm_away
data: {}
message: Blink Cameras ARMED because Abode was set to Armed
mode: single
- To no avail, I also tried the arming with events swapped in for the trigger, with the
event_code
formatted as a string like'1374'
: and as an integer like1374
- platform: event
event_type: abode_arm
event_data:
event_code: 1374
- platform: event
event_data:
event_code: 1456
- platform: event
event_data:
event_code: 3400
- platform: event
event_data:
event_code: 3401
- platform: event
event_data:
event_code: 3407
- platform: event
event_data:
event_code: 3408
- platform: event
event_data:
event_code: 3456
- platform: event
event_data:
event_code: 3758
Does anyone have any ideas / have a working Abode Alarm arming trigger / YAML they could share?
Thank you!
