I have a question whether this is possible or not. Currently I do have a lot of automation which is fine, but with this i had a lot of problems.
So here is what I want to accomplish:
Motion Sensor Calls my 3 Lamps…
From 3 - 8 am my lamps should have an Level of 20 %.
The rest of the Day should be fully 100 Prozent of the light level.
There are definitely more efficient ways of doing this but you could just create 2 automations 1 for each time period and create the conditions in each automation
This will turn my office light on at 20% if motion is detected between 3-8
Then you can just duplicate this but change the time frame (8-3) and set the brightness to 100%
You can take this a step further by a helper. For example I use a Time of the Day helper called “evening” which is set at 19:00 - 24:00. I then check the condition of the helper in my automations - evening will be on between 19:00-24:00. this means if I want to adjust the timeframe instead of having to edit all my automations I edit the helper and all automations will be impacted.
Sure some else will be along with a much more elegant solution soon but in the interim I hope this helps
