I am trying to do something that seems really simple but it’s just not working…its an automation.
Input : when solar power being generated is more then 2000w
Then: turn on a switch (that Has a fan on it to provide extra cooling to my inverter).
Attempt 1: using the trigger of a numeric value…I put in the entity id and 2000
Nothing happens.
Attempt 2: using the threshold helper I made a helper called ‘solar’, told it to become ‘on’ when the solar energy being produced is over 2000…
I created an entity id card that definitely shows on if it is above 2000 and off if below …
However I can’t seem to get it working in automations to trigger turning on the fan.
In the first and second screenshot’s Attribute field, what is this value named ‘Sensor value’? That looks like something random you typed into the field. Remove it.
Note:
When sharing information with the community, it’s preferable to post the YAML produced by the Automation Editor as opposed to screenshots (it’s mentioned in the FAQ and, if you look around this forum, that’s what most users do).
