mcfrojd
(Mcfrojd)
1
How do i make an automation that control my input_boolean depending on these states?
And it needs to work if HA reboots to!
sensor1 (on / off)
sensor2 (on / off)
group1
sensor1
sensor2
I want the input_boolean to be ON:
if sensor1 OR sensor2 is “on”
(or if group1 is “on”) ?
I want the input_boolean to be OFF:
if sensor1 AND sensor2 is “off”
(or if group1 is “of”) ?
petro
(Petro)
2
Are you going to be using the input Boolean in the interface? I mainly ask because it looks like you want a sensor, not an input boolean.
sensors:
my_on_off_thing:
value_template: >
{{ ( is_state('sensor.sensor1','on') and is_state('sensor.sensor2','on') ) or is_state('group.group1','on') }}
mcfrojd
(Mcfrojd)
3
Right now im only using it for simulation.
When i see that it works as i need it to work it is suppose to control a waterheater.
