I am working on an apex chart card to display body stat info, but I cannot seem to get it quite right. Basically, I am wanting to stack the values to equal a total weight and display that info as such on the chart. Below is what i have so far… as you can see the values are displayed, but they should be in addition to the previous value… so 0+8.4+50.2+161 NOT 0-8.4 then 0-50.2 then 0-161, etc.
I still would like to display the total weight value in the header, but it would not be required on the chart as all the other values would equal the total weight.
Any help is appreciated
type: custom:apexcharts-card
graph_span: 7d
span:
end: day
offset: '-1sec'
header:
show: true
title: Andrew's Body Stats
show_states: true
colorize_states: true
all_series_config:
stroke_width: 0
type: line
color_list:
- green
- blue
- orange
- yellow
series:
- entity: sensor.andrew_withings_weight
type: area
group_by:
func: last
duration: 24h
- entity: sensor.andrew_withings_muscle_mass
type: area
group_by:
func: last
duration: 24h
- entity: sensor.andrew_withings_fat_mass
type: area
group_by:
func: last
duration: 24h
- entity: sensor.andrew_withings_bone_mass
type: area
group_by:
func: last
duration: 24h
apex_config:
cache: true
tickAmount: 10
dataLabels:
enabled: true
dropShadow:
enabled: true
chart:
zoom:
enabled: true
toolbar:
show: true
tools:
zoom: true
zoomin: true
zoomout: true
pan: true
reset: true
fill:
type: gradient
gradient:
shadeIntensity: 0.1
opacityFrom: 0.25
opacityTo: 1
inverseColors: true
stops:
- 0
- 70
- 100
