andrew101
(Andrew)
January 29, 2022, 11:40pm
1
Hi, I have a battery powered device that I want to be recharged every few weeks. The charger is permanently plugged into a Sonoff S31 outlet/power meter running Tasmota which is set up in Home Assistant.
I was thinking to have Home Assistant turn on the charger every three weeks, wait a minute for the power reading from the S31 to stabilize, then turn it off when the power drops below 5 watts.
This would let the battery run down over a few weeks, then charge it up without letting it continue charging once it is full.
I know this is overkill but I enjoy this kind of project!
I’m not familiar with all the options for scripting Home Assistant - does anyone have general suggestions on a good way to do this?
finity
January 30, 2022, 2:48am
2
I have some Lithium Ion batteries I do this exact thing with but I recharge them every week. You could easily modify it to 3 weeks.
you need an input_datetime to hold the date & time the charger was turned off:
input_datetime:
charger_1_off_time:
name: Charger 1 Turned Off At
has_date: true
has_time: true
the automations include announcements to let me know when charging is complete.
And I have several batteries I monitor/charge so they are included where appropriate.
then the automations for one charger become:
automation:
- alias: Garage Power Charger 1 Check Charging
- platform: state
entity_id: switch.garage_power_strip_switch_1
to: 'on'
for:
minutes: 5
- platform: numeric_state
entity_id: sensor.garage_power_strip_power_1
below: 3.0
for:
minutes: 5
condition:
- condition: template
value_template: '{{ states("sensor.garage_power_strip_power_1") | float < 3.0 }}'
- condition: state
state: 'on'
- service: switch.turn_off
- condition: time
before: '20:00:00'
- condition: time
after: '10:00:00'
- service: notify.alexa_media
- media_player.garage_dot
- media_player.kitchen_dot
type: tts
message: "Charger number 1 has either completed charging or doesn't have a battery connected and it has been turned off."
- alias: Garage Power Chargers Set Off Time
- platform: state
entity_id:
- switch.garage_power_strip_switch_1
- switch.garage_power_strip_switch_2
- switch.garage_power_strip_switch_3
- switch.garage_power_strip_switch_4
to: 'off'
- service: input_datetime.set_datetime
entity_id: >
{% if trigger.entity_id == 'switch.garage_power_strip_switch_1' %}
input_datetime.charger_1_off_time
{% elif trigger.entity_id == 'switch.garage_power_strip_switch_2' %}
input_datetime.charger_2_off_time
{% elif trigger.entity_id == 'switch.garage_power_strip_switch_3' %}
input_datetime.charger_3_off_time
{% elif trigger.entity_id == 'switch.garage_power_strip_switch_4' %}
input_datetime.drill_charger_off_time
{% endif %}
timestamp: "{{ now().timestamp() }}"
- alias: Garage Power Chargers Refresh Battery Charge
value_template: "{{ as_timestamp(now()) - state_attr('input_datetime.charger_1_off_time', 'timestamp') | int > 86400 * 7 }}"
value_template: "{{ as_timestamp(now()) - state_attr('input_datetime.charger_2_off_time', 'timestamp') | int > 86400 * 7 }}"
value_template: "{{ as_timestamp(now()) - state_attr('input_datetime.charger_3_off_time', 'timestamp') | int > 86400 * 7 }}"
value_template: "{{ as_timestamp(now()) - state_attr('input_datetime.drill_charger_off_time', 'timestamp') | int > 86400 * 7 }}"
- service: switch.turn_on
entity_id: >
{% if trigger.id == 'chg_1' %}
{% elif trigger.id == 'chg_2' %}
{% elif trigger.id == 'chg_3' %}
{% elif trigger.id == 'chg_4' %}
{% endif %}
andrew101
(Andrew)
January 30, 2022, 5:07am
3
Thank you, this is very helpful, I was able to adapt it to my setup and it looks like it will work.
