Help with automated lights
I currently have the following automation for my landing light, however looking for some help to achieve the following:
from sunset to 23:00 I want it to do exactly what it does now, however from 23:00 to sunrise I want the light to only come on to 5%
how would I go about doing that?
my current automation: https://pastebin.com/NnQdqt7F
Please format your YAML code properly following the instructions at the top of the page. As it is, it is very difficult to read.
You can use conditions in the action as well. (https://www.home-assistant.io/docs/automation/action/)
When posting configuration snippets please use code blocks and syntax highlighting.
sorry, quite new to this, I’ve pasted it into pastebin https://pastebin.com/NnQdqt7F
You might want to add something like the following snippet (untested) in your action part of your automation.
      - service: light.turn_on
          brightness_pct: 5
          entity_id: light.yeelight_landing
      - condition: time
        before: '23:00'
          brightness_pct: 100
Pasting code here is fine. Just use proper tags to format your code.
```yaml
  - condition: time
    before: '23:00'
I would use a data_template:
    - service: homeassistant.turn_on
      data_template:
        brightness_pct: "{{ 5 if now().hour >= 23 else 100 }}"
