So I have this automation, and it works, but I’ve found that my devices go offline a bit more than I realized. So I end up getting a lot of alerts. I do want to know if a device goes offline and if it goes online, but I really only want to know if they have been offline for an extended period of time (like maybe 30 minutes)
but that does not cover when it comes back online
I could do two triggers one for home and one for not home, but then I’d end up getting a lot of messages for items coming online. I think I need a condition that the state of the trigger device has not changed in 30 minutes, along with the for: 30 minutes in the trigger??
Just looking to see what others have done for stuff like this
Maybe this can help. To be honest I am not 100% sure how it works but it might give you some idea’s.
If my garage is left open for 30 minutes I get an alert, every 30 minutes. When it closes I get another alter saying that it has closed.
I use PushBullet for my notifier.
alert:
garage_door:
name: Garage is open
done_message: Garage is closed
entity_id: cover.mqtt_cover
state: 'open'
repeat: 30
can_acknowledge: true
skip_first: true
notifiers:
- PB_NOTIFIER
You can just change the parameter for each device tracker to “consider_home: 1800”. This won’t set to not_home if the offline duration is smaller than 30 minutes.
I need to read about the device_tracker component because I don’t understand its application for tracking Amazon Echo Dots, Philips Hue Hubs, Ecobee Thermostats, etc.
Can I set each device individually? I did not realize that, I’ll have a look. I have a few presense sensors using the same device tracker (wi-fi) that I dont want to set to 30 minutes.
So if you are mainly concerned with being notified when they drop out, why not just include the for: x time in your trigger? You could create another automation to let you know that it has come back online where it has a condition to restrict it notifying you unless the device had been offline for x time as well. That way any short dropout wont create a notification
- alias: "Notify if HA Device Offline"
- platform: state
entity_id:
- device_tracker.amazon_dot_ashleys_room
- device_tracker.amazon_dot_bedroom
- device_tracker.amazon_dot_living_room
- device_tracker.amazon_dot_office
- device_tracker.appletv
- device_tracker.ecobee_downstairs
- device_tracker.ecobee_upstairs
- device_tracker.fire_tv_theater_room
- device_tracker.front_doorbell_camera
- device_tracker.harmony_hub_living_room
- device_tracker.harmonyhub_frog
- device_tracker.hue_hub
- device_tracker.office_pc
- device_tracker.plexserver
- device_tracker.slingbox
- device_tracker.sonos_playbar_living_room
- device_tracker.sonos_sub_living_room
- device_tracker.sony_tv_living_room
- device_tracker.tivomini_bedroom
- device_tracker.tivomini_theater_room
- device_tracker.vizio_tv_bedroom_lan
- device_tracker.vizio_tv_cast_bedroom_wireless
- device_tracker.vizio_tv_theater_room_lan
to: 'not_home'
for:
minutes: 20
condition:
- condition: numeric_state
entity_id: sensor.ha_runtime_in_minutes
above: 10
- service: notify.pushover
data_template:
target: Paul
title: "Device Status"
message: "{{ trigger.to_state.attributes.friendly_name }} is {{ trigger.to_state.state }}"
- alias: "Notify if HA Device Online"
- platform: state
entity_id:
to: 'home'
condition:
above: 10
- condition: template
value_template: "{{ is_state('trigger.entity_id','not_home') ### I MAY HAVE THIS TEMPLATE A BIT WRONG, BUT YOU GET THE IDEA ###
for:
minutes: 20
data_template:
target: Paul
