Help with Automation: Error rendering data template: TypeError: argument of type 'NoneType'
my alarm automation throws error in the log when i disable the alarm from the Smartphone.
If Alarm is turned off the attributes becomes nothing so homeassistant throws an error.
Could anyone help to solve this please ?
- alias: Wecker - Set Alarm Input Helper
    - platform: state
      entity_id: sensor.martin_smartphone_next_alarm
    - service: input_datetime.set_datetime
      data_template:
        entity_id: input_datetime.wakeup_martin_smartphone
        datetime: >-
          {% if 'com.sec.android.app.clockpackage' in (state_attr('sensor.martin_smartphone_next_alarm', 'Package' )) %} {{
            states('sensor.martin_smartphone_next_alarm') |as_datetime |as_local }} {% endif %}
  mode: restart
Error in Log:
Logger: homeassistant.components.automation.wecker_set_alarm_input_helper
Source: components/automation/init.py:514
Integration: Automatisierung (documentation, issues)
First occurred: 11:49:26 (2 occurrences)
Last logged: 11:49:57
Error while executing automation automation.wecker_set_alarm_input_helper: Error rendering data template: TypeError: argument of type 'NoneType' is not iterable
Error while executing automation automation.wecker_set_alarm_input_helper: Invalid datetime specified: for dictionary value @ data['datetime']
Thanks in advance :wink:
you aren’t providing an else. So when ‘com.sec.android.app.clockpackage’ is not in state_attr(‘sensor.martin_smartphone_next_alarm’, ‘Package’ ), the service executes with None as the datetime: result and the service errors.
You should use choose if you don’t plan on firing the service when your if statement is not met. That way, there won’t be a service and you won’t get the error.
Secondly, data_template is deprecated, just use data. The requirement for data_template is a thing of the past, it’s no longer required.
Thanks petro.
Could you provide a sample how it should look?
I’m a total beginner, sorry.
Take a look at the choose examples
