I want to have 3 simple automations… using the GUI it seems for the first one i cant do much…
i want to be turn on a light outside from 7PM to 6AM, i tried the below in automations.yaml…
- alias: Turn on outside light at 7.30 pm
platform: time
at: "\u201919:30:00'"
service: homeassistant.turn_on
entity_id: switch.outside_lamp_switch_5_0
- alias: Turn off outside light at 6.30 am
platform: time
at: "\u20196:30:00'"
service: homeassistant.turn_off
The next automation i wanted to do was turning on a light on motion and off with no motion after 10 minutes…
this I was able to do using the GUI but seems to not “get the” entity value stored…
here is what i have in automations.yaml for light on.
- action:
- alias: Turn Kitchen Light on
alias: Turn on kitchen light when there is movement
- entity_id: binary_sensor.linear_wapirz1_motion_sensor_sensor_8_0
platform: state
to: 'on'
i tried to follow documentation but seems doing something incorrectly…
sorry i was not near a system so couldnt update the post…
The below does not work.
platform: time
platform: time
This also does not work.
- action:
platform: state
to: 'on'
@jayha Battery devices will show as sleeping. In the case of a motion sensor, it will always respond to a motion event, and wake up the Zwave radio to report to HA. Since motion can be almost continuous, motion sensors usually have a timeout value, something like 4 or 5 minutes between times that they wake up the Zwave radio to report. Each new motion event will reset the timeout. 5 minutes (or what ever value set in the sensor) after the last motion event, the sensor wakes up the Zwave radio and notifies HA that there is no motion. A motion event immediately wakes the Zwave radio to report. You need to have a look at your documentation for the motion sensor to see what the timeout value is and make sure the timeout in your automation is at least as long as the timeout in the sensor.
