that’s my first time here
Components involved: Shelly plus 1PM ( switch ) and 2 stripLed dual White >> 2 controller
( 1 Gledopto and 1 MIlight) driven by the same Power Source (75w)
by the way, this a part of automation_test >>> “it works” but
button1_single_press:
- choose:
- conditions:
- condition: state
entity_id: switch.livingroom_switch
state: 'off'
sequence:
- service: light.turn_on
entity_id: light.Living1_wdhigh
transition: 3
kelvin: 3200
brightness_pct: 15
- service: light.turn_off
entity_id: light.Living2_wdlow
- service: switch.turn_on
- conditions:
- condition: state
state: 'on'
sequence:
entity_id: light.soggiorno1_wdhigh
transition: 3
brightness_pct: 15
kelvin: 3000
default: []
I got a tricky point on option1:
switch_turn on works but automation doesn’t turn_off the 2ndLight Living2
it seems it is such as “sleep mode”, the light appears ( from my view obviously ) in default_state setting I assume
After i did press the other Buttons i.e turn_off both lights not the the Switch
and press Button1 as at the begin : it works !!!
Any idea how to solve it?
Suggestions how to proceed are wellcome
Sorry for the explanation non in technical way, I will learn as much as better next topic
Thanks in adv for all contributions
