I need some help setting up a (what i thought to be a) simple automation:
I’ve got a relay and a sensor. and all i want is when a button is pressed, to check the sensor, and if the value is above a certain point to switch teh relay on and then leave it on until the certain point is met.
now, i got as far as getting the relay to be switched on after checking the value, but then i don’t know how to turn it off again after the value is met.
I tried is with a “while” and a “wait_until” action, but then it seems to switch the relay on and on and on again. (supposedly until the value is met, but i never get this far because then the logs throw an error that the esp node disconnected from the api and the relay is switched off…)
Please point me in the right direction for a solution.
Here’s what I have so far (which doesn’t work):
- platform: vl53l0x
address: 0x29
update_interval: 500ms
long_range: true
button:
on_press:
then:
- if:
condition:
lambda: 'return id(distance1).state < 0.24;'
then:
- switch.turn_on: relay_up
- wait_until:
lambda: |-
(return id(distance1).state = 0.24);
- switch.turn_off: relay_up
on_press:
- while:
condition:
lambda: |-
return id(distance1).state > 0.09;
then:
- switch.turn_on: relay_down
