Does your rf controlled fan report it’s current state to Home Assistant?
If not, then there is nothing you can do to prevent it getting out of sync due to control external to HA without extra hardware (e.g. current monitoring, or a different smart switch)
If it does report its state than yes there are a few ways to prevent your issue. e.g. Using a state condition in your automation, or creating a template fan that has discrete on and off states.
the fan is not being exposed to HA as i couldnt find a way to expose the IR to HA. im only able to control the fan via an entity scene which is created from a tap to run in smartlife.
i.e. i am controlling the fan only as an entity.
separate quick question, i would imagine the fan will be turn ‘on’ twice if the humidity is at 75 and later at 80? are we able to switch off this automation once this is triggered?
im afraid this is not possible now. its a hardwire switch and i dont intend to make any ‘reno’ changes. so im exploring if there anything that can be done ‘digitally’.
what about i do this →
if >75% turn fan on, ‘then do’ wait for trigger for humidity to <65, then turn fan off.
i guess this would solve the issue of if >75 fan turn on then within 30 mins it goes below 75 and back up to >75 again, it will trigger the on and effectively turning it off.
i would then be left with, if the fan current state is on, nothing can be done about it.
actually, thinking out loud, while this can detect its on state, when the fan is actually running for say 2hours, wouldnt the device continuously report vibration for 2 hours non stop? would then this kill the battery?
Those battery powered devices tend to only report state changes. Once the unit starts vibrating, it will send an update and then power down as much of the device as it can. When the unit stops vibrating, it’ll power back up to send the next update and then go back into low power mode waiting for the next event.
