I’m new to HA, running on blue. I just moved from deCONZ to zigbee2mqtt since the dimmer remote I want to use would not pair with deCONZ. It’s an AONE Aurora AU-A1ZBR2GW wireles dual rotary dimmer.
I was setting up automations for it and started with setting the left dimmer to a light group, and the right one to a single bulb. Worked fine. I moved on to set the on/off toggles, and while they too worked as expected, the dimmer automations stopped working right then.
I changed nothing in between, they worked consistently until I moved on the the other automations, and now they just WILL NOT fire. I’ve deleted them all and back to trying to get just one to work. I also tried disabling all the other automations. I can run the actions manually.
Here is the automation:
alias: aurora_dimmer_ljosakrona_up
description: ''
- platform: device
domain: mqtt
device_id: 2d6cf9148cd4263ce2dcaf9e1a1b78b3
type: action
subtype: color_temperature_step_up_left
discovery_id: 0x000d6ffffec1bdcc action_color_temperature_step_up_left
condition: []
- service: light.turn_on
entity_id: light.ljosakrona
transition: 1
brightness_step_pct: 5
mode: single
A screen capture that shows that HA actually sees the events firing:
