I want to create a homeassistant script which can be activate by pressing a virtual switch “A”
The HA checks if the “temp_hum_living_room_temperature” sensor is reporting temperature of > 19.5 then it switches off TRV “climate.trv_living_room_front_thermostat” and “climate.trv_living_room_back_thermostat”. Automation then turns up the thermostat “climate.boiler_verstile” to 2 degree C above the current value. If the sensor “temp_hum_living_room_temperature” is reporting temperature of < 19.5 then it increases the temperature of TRV “climate.trv_living_room_front_thermostat” and “climate.trv_living_room_back_thermostat” to 2 degree above their current value and turns on HVAC mode on these two TRVs to Heat and when the “temp_hum_living_room_temperature” sensor is reporting temperature of > 19.5 then it switches off TRV “climate.trv_living_room_front_thermostat” and “climate.trv_living_room_back_thermostat”. The automation ends when the sensor “sensor.atc4_store_temperature” reports temperature of >19C"
Being a noob I asked chatGPT the above. It came up with the following code
# configuration.yaml
# Define the virtual switch "A"
input_boolean:
virtual_switch_a:
name: Virtual Switch A
icon: mdi:light-switch
# Define the automation
automation:
- id: temperature_automation
alias: Temperature Control Automation
platform: state
entity_id: input_boolean.virtual_switch_a
to: "on"
service: script.temperature_control
# Define the script
script:
temperature_control:
sequence:
- condition: numeric_state
entity_id: sensor.temp_hum_living_room_temperature
above: 19.5
- service: climate.set_hvac_mode
entity_id: climate.trv_living_room_front_thermostat
hvac_mode: "off"
entity_id: climate.trv_living_room_back_thermostat
hvac_mode: "off"
- service: climate.set_temperature
entity_id: climate.boiler_verstile
temperature: "{{ state_attr('climate.boiler_verstile', 'temperature') + 2 }}"
- wait_template: "{{ states('sensor.temp_hum_living_room_temperature') | float > 19.5 }}"
below: 19.5
temperature: "{{ state_attr('climate.trv_living_room_front_thermostat', 'temperature') + 2 }}"
temperature: "{{ state_attr('climate.trv_living_room_back_thermostat', 'temperature') + 2 }}"
hvac_mode: "heat"
hvac_mode: "heat"
hvac_mode: "off"
hvac_mode: "off"
However when i save this in HA i get error “Message malformed: extra keys not allowed @ data[‘script’”. Any ideas and any help with this automation?
