Help with automation trigger itself when I reloaded Xiaomi gateway integration
Hi all,
I’m having trouble with this automation, I have many automation configured and somehow when I manually trigger the reload of ‘Xiaomi Miio’ or ‘Xiaomi Gateway 3’ Integration, basically reload the gateway integration, some of the automation will auto trigger itself, below is one of the examples.
I am running out of idea what could be the root cause, please enlighten me If you have the solution, thanks!
This is the code I configured.
alias: Kitchen_Temperature Sensor - Below 32°C - Exhaust Fan Off
description: ""
  - type: temperature
    platform: device
    device_id: c183c245192668cc0898c5be02ccea77
    entity_id: sensor.0x00158d0001199959_temperature
    domain: sensor
    below: 32
condition:
  - condition: numeric_state
    below: 32
  - type: turn_off
    device_id: f92eb9540ab9c3bebc82efa66a535d22
    entity_id: switch.0x00158d000153b15b_channel_1
    domain: switch
mode: single
This is the ‘Change Variables’ I copied and pasted from ‘Traces’
this:
  entity_id: automation.kitchen_temperature_sensor_below_32degc_exhaust_fan_off
  state: 'on'
  attributes:
    last_triggered: '2022-09-19T16:03:58.560984+00:00'
    mode: single
    current: 0
    friendly_name: Kitchen_Temperature Sensor - Below 32°C - Exhaust Fan Off
  last_changed: '2022-09-19T16:01:15.015996+00:00'
  last_updated: '2022-09-19T16:03:58.568623+00:00'
  context:
    parent_id: 01GDB7VWYDJTDY234SXWXJBBWE
    user_id: null
  idx: '0'
  alias: null
  platform: device
  below: 32
  above: null
  from_state:
    state: unavailable
    attributes:
      restored: true
      state_class: measurement
      device_class: temperature
      friendly_name: Kitchen Thermometer Sensor Temperature
      supported_features: 0
      unit_of_measurement: °C
    last_changed: '2022-09-19T16:05:32.982250+00:00'
    last_updated: '2022-09-19T16:05:32.982250+00:00'
    context:
      parent_id: null
      user_id: null
  to_state:
    state: '30.78'
    attributes:
      native_value: 30.78
    last_changed: '2022-09-19T16:05:33.556502+00:00'
    last_updated: '2022-09-19T16:05:33.556502+00:00'
    context:
      parent_id: null
      user_id: null
  for: null
  description: numeric state of sensor.0x00158d0001199959_temperature
When you reload the integration, the value of its sensors is reset to unavailable first and then to the actual value. The temperature sensor’s change from unavailable to a numeric value below 32 is what triggers the Numeric Device Trigger.
Add a Template Condition that blocks if the sensor’s previous value was unavailable.
description: ""
  - type: temperature
    platform: device
    domain: sensor
    below: 32
condition:
    below: 32
  - condition: template
    value_template: "{{ trigger.from_state.state != 'unavailable' }} "
  - type: turn_off
    domain: switch
mode: single
FWIW, the Numeric State Condition is redundant because it simply confirms what the Numeric Device Trigger is already doing (i.e. it triggers only when the temperature decreases below the threshold value of 32). It can be removed.
This is what I am looking for 123 Tara, let me apply to my Automations and I shall update the outcome here, thanks!
description: ""
  - type: temperature
    platform: device
    domain: sensor
    below: 32
condition:
  - type: turn_off
    domain: switch
mode: single
What if I want to add an Unknown state as well?
can I use 1 line as
{{ trigger.from_state.state != 'unavailable' or 'unknown}}
or I shall add one more template instead?
condition:
    value_template: >
    value_template: >
              {{ trigger.from_state.state != 'unknown' }}
If it fails to work, replace the Numeric Device Trigger with a Numeric State Trigger.
description: ""
  - platform: numeric_state
    below: 32
condition:
  - type: turn_off
    domain: switch
mode: single
condition:
    value_template: "{{ trigger.from_state.state not in ['unavailable', 'unknown'] }}"
I did this for another automation, it sync the status if AirConditioner is triggered manually by the physical remote control.
alias: Study Room_OC Sensor - Open - Turn On AC
description: ""
  - type: opened
    platform: device
    device_id: bbf68c05e40aa566d484c6c785f90ff4
    entity_id: binary_sensor.0x54ef441000250727_contact_2
    domain: binary_sensor
condition:
    value_template: "{{ trigger.from_state.state != 'unknown' }} "
  - service: switch.turn_on
    data: {}
      entity_id: switch.study_room_sensibo_ac_switch
mode: single
Did what I suggested prevent the automation from triggering after the integration was reloaded?
I added the coding below to all my Automation and monitor for a day and didn’t encounter any issue, thanks, issues resolved.
  condition:
    value_template: '{{ trigger.from_state.state not in [''unavailable'', ''unknown'']
seems that i shouldn;t at it to automation that triggers by timer, have to remove it or else wont work. :-/
If the automation is triggered by a Time Trigger, the trigger variable doesn’t have from_state and to_state properties, it only has platform and time properties.
got it, thanks.
