Hi…
I’m trying to get an automation working but I can’t seem to get it to trigger on numeric state change.
my goal…
turn my pool pump to low when the temp difference of my solar sensor is greater then 19 (and keep it on as long as the temp difference is above 19)
I have a separate automation to turn the pump off when the solar temp diff is below 20
my sensor works and reports the correct values
sensors:
# SOLAR TEMP DIFF
solar_temp_diff:
value_template: "{{ states('sensor.pentair_airtemp') | int - states('sensor.pentair_soltemp') | int }}"
I have used this format for other automations and it works fine
alias: pool - solar circulation (on)
description: turn pool pump to L if solar temp diff greater than 20
- platform: numeric_state
entity_id: sensor.solar_temp_diff
above: '19'
condition: []
- service: switch.turn_on
data: {}
entity_id: switch.pentair_pooll
mode: single
For some reason, it appears the automation does NOT recognize the trigger on numeric_state
your input is appreciated.
Thank
Dave
Hi dave, I have a doubt, you said you want to turn on the pump above 19 and turn off pump below 20. 19 is also below 20. If you meant you want to stop the pump above 20, I have tried to combine both your automations together by using the choose action type and also template triggering. You may need to change some things according to your settings.
description: ''
mode: single
- platform: state
condition: []
- choose:
- conditions:
- condition: template
value_template: '{{ states(''sensor.solar_temp_diff'') | float <= 20 }}'
sequence:
- service: switch.turn_off
entity_id: switch.water_pump
- conditions:
value_template: '{{ states(''sensor.solar_temp_diff'') | float >= 19 }}'
sequence:
default: []
Thank you for this!!!
Yes, basically want to turn my solar circulation pump on/off at 20. Changed up the value template based on what you sent accordingly.
" >= 20 turn on
" < 20 turn off
I didn’t even think that was an option.
Newish to homeassistant and still thinking within the constraints of my old automation system.
The more I use/learn homeassistant, the more I’m wondering what took me so long to find it!
I’m using the GUI to setup automations and was under the impression that you could not just pick an “entity” or a “device” as a trigger without filling in the additional information (to, from, for, etc…)
This tidbit of information has allowed me to cut the number of automations I was using in half! I was previously using separate automations for on and off.
Thank you again!
d
while we are at it… is there a better way to do this???
shutdown MariaDB before automated SambaBackup runs and then restart MariaDB once backup is complete.
My automated backup runs at 01:00 and this is what I have tried so far. It appears to be working, but am unable to track the process down in the logs to verify.
alias: backup - shutdown/restart mariadb
description: ''
- platform: time
at: '12:59:45'
condition: []
- service: hassio.addon_stop
addon: core_mariadb
- wait_for_trigger:
- platform: state
entity_id: sensor.samba_backup
to: SUCCEEDED
attribute: last_backup
- service: hassio.addon_start
addon: core_mariadb
mode: single
Since you are looing for automated snapshot process, I would highly recommend this addon.
This can do snapshots with addons turned on and then turn them off, also it can upload snapshots to google drive which can be one more redundancy factor. There are lots more features and the addon is worth it.
