Help with Automations - Consolidation
Hey i have several automations which are doing almost the same.
I set up a alarm card for common alarms which trigger sonos and will fade in lights with a single tap.
All of that works quiet well but my automations file and gui are bloated just because the whole alarm thing.
So i have some code which differs a bit.
- alias: Disable Sonos Alarm 6:00
  - platform: state
    entity_id: input_boolean.alarm_clock_six
    to: 'off'
    service: sonos.update_alarm
    data_template:
      entity_id: media_player.bedroom_sonos
      alarm_id: 1129
      enabled: false
and another alarm would look like:
- alias: Disable Sonos Alarm 8:00
  - platform: state
    entity_id: input_boolean.alarm_clock_eight
    to: 'off'
    data_template:
      alarm_id: 1233
      enabled: false
So the only things that changhed are the entity id of the trigger and the alarm id in the action.
Is there a way to consolidate this into only one automation? or is that not possible because it has different triggers?
Thanks in advance
It’s possible, but it doesn’t gain you much:
  - platform: state
    to: 'off'
  - platform: state
    to: 'off'
  - choose:
      # At 6 AM
      - conditions: "{{ trigger.id == 'six_am' }}"
        sequence:
          - service: sonos.update_alarm
              alarm_id: 1129
              enabled: false
    # At 8 AM
    default:
          alarm_id: 1233
          enabled: false
You should also go through your config and do a search and replace for all instances of data_template and replace with just data and for service_template replace with just service.
That is exactly what i was searching for. Big thanks!
Ok this is what im looking for but sadly its not working for me.
i think this has to do with the actions. can you help me with that?
What is not working?
What errors do you get?
How did you test it?
The automation is not working. So the alarm for 6am and 8am are not disabled.
i dont get specific errors but the alarms stay enabled.
i tested this by disabling my previous automations and enabled yours but after changing the state of input_boolean.alarm_clock_eight oder input_boolean.alarm_clock_six nothing happens
Try this instead:
  - platform: state
    to: 'off'
  - platform: state
    to: 'off'
      alarm_id:  >
        {% if trigger.id == "six_am" %}
          1129
        {% else %}
          1233
        {% endif %}
      enabled: false
Im so sorry. Both versions are working i had a typo in my config. after changing this it works perfect.
Thank you so much for the fast help!
Yet one more way to do the same thing:
  - platform: state
    entity_id:
    - input_boolean.alarm_clock_six
    - input_boolean.alarm_clock_eight
    to: 'off'
      alarm_id: "{{ 1129 if 'six' in trigger.to_state.object_id else 1233 }}"
      enabled: false
Ok one more thing im struggeling with. This is a bit different from my first question because conditions are different.
also i think trigger should be swapped the condition (input_boolean). This was one of my first automations so i don’t know what happened there :smiley:
So when i togglethe switch the lights should slowly fade in 15 minutes before the time the alarm should go off. So platform time is 7:45 for the 8:00 alarm.
It always starts the same script but based on a different sonos alarm which starts the lights 15 minutes before the alarm.
- alias: Fade in Lights in Bedroom 8:00
  - platform: time
    at: 07:45:00
  condition:
  - condition: state
    state: 'on'
  - condition: time
    weekday:
    - mon
    - tue
    - wed
    - thu
    - fri
    service: script.bedroom_light_fade_in
and
- alias: Fade in Lights in Bedroom 6:00
  - platform: time
    at: 05:45:00
  condition:
  - condition: state
    state: 'on'
  - condition: time
    weekday:
    - mon
    - tue
    - wed
    - thu
    - fri
i tried to do it like this:
  condition:
  - condition: state
    state: 'on'
    entity_id:  >
      {% if trigger.id == "six" %}
      {% else %}
      {% endif %}
but i think its not working in conditions.
Any ideas?
Have you defined any trigger ids?
Show the whole automation.
Also the state condition can not use templates.
- id: '1629721388503'
  alias: Fade in Lights Bedroom
  - platform: time
    at: 05:45:00
  - platform: time
    at: 14:30:00
  condition:
  - condition: state
    state: 'on'
    entity_id:  >
      {% else %}
      {% endif %}
  - condition: time
    weekday:
    - mon
    - tue
    - wed
    - thu
    - fri
    service: script.bedroom_light_fade_in_zehn
  mode: single
So i should switch the automation to something with as a trigger with input_boolean.alarm_clock_six and set the time as a condition?
This is not valid. You cant use templates there.
  condition:
  - condition: state
    state: 'on'
    entity_id:  >
      {% else %}
      {% endif %}
You can only use templates under data:, service:, or target: and in some rare configuration options specifically defined in the documentation.
You can do it like this:
  condition:
    - condition: or
      conditions:
        - condition: and
          conditions:
            - condition: state
              state: 'on'
            - condition: trigger
        - condition: and
          conditions:
            - condition: state
              state: 'on'
Or considerably more compact:
  condition:
    - condition: or
      conditions:
        - "{{ states('input_boolean.alarm_clock_six', 'on') and trigger.id == 'six' }}"
        - "{{ states('input_boolean.alarm_clock_eight', 'on') and trigger.id == 'test' }}"
This uses a specific shorthand for template conditions introduced a few updates ago. Using traditional longhand template conditions it would look like this:
  condition:
    - condition: or
      conditions:
        - condition: template
          value_template: "{{ states('input_boolean.alarm_clock_six', 'on') and trigger.id == 'six' }}"
          value_template:  "{{ states('input_boolean.alarm_clock_eight', 'on') and trigger.id == 'test' }}"
See: https://www.home-assistant.io/docs/scripts/conditions/#template-condition
Wow. Thats some nice stuff.
How do implement the weekdays condition?
On your first example im pretty sure its just another condition under it.
But how in the compact way?
I will try out the compact style and will tell if it works.
Like so:
  condition:
    - condition: or
      conditions:
    - condition: time
      weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
Conditions are AND logic by default, so we have: either of the templates must be true and the weekday condition must be true.
It could also be done like this (using shorthand templates again):
  condition:
    - condition: or
      conditions:
    - "{{  0 <= now().weekday() <= 4 }}"
So i have this code:
- id: Fade in Lights Bedroom Test
  - platform: time
    at: 05:45:00
  - platform: time
    at: 14:30:00
  condition:
    - condition: or
      conditions:
    - condition: time
      weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
    - service: script.bedroom_light_fade_in
  mode: single
and it gives me this error:
Invalid config for [automation]: Expected HH:MM, HH:MM:SS or Entity ID with domain ‘input_datetime’ or ‘sensor’ @ data[‘at’][0]. Got None. (See /config/configuration.yaml, line 12).
In the first two templates, replace states with is_state.
The third template can be reduced to this because isoweekday reports Monday as 1 and Sunday as 7.
    - "{{ now().isoweekday() <= 5 }}"
Geez I’m making a mess tonight. Might be time for bed. Fixed:
  condition:
    - condition: or
      conditions:
        - "{{ is_state('input_boolean.alarm_clock_six', 'on') and trigger.id == 'six' }}"
        - "{{ is_state('input_boolean.alarm_clock_eight', 'on') and trigger.id == 'test' }}"
  - platform: time
    at: 05:45:00
  - platform: time
    at: 14:30:00
  condition:
    - condition: or
      conditions:
  mode: single
gives me the same error: Invalid config for [automation]: Expected HH:MM, HH:MM:SS or Entity ID with domain ‘input_datetime’ or ‘sensor’ @ data[‘at’][0]. Got None.
Try this
  - platform: time
    at: '05:45:00'
  - platform: time
    at: '14:30:00'
