Im trying to create a blueprint that executes a specific behavior controlling two lights with a lutron caseta remote.
- For the On button Both lamps turn on.
- For the raise button :
I want to make sure that the brightness of the lamp that’s on is increased. If there 1 lamp on ,and the other off, I want the brightness to only increase on the one that’s on.
cases:
Both lamps are off: increase brightness by 2
Both lamps are on: increase brightness by 2%
Only 1 lamp is on: increate brightness by 2% on the one that’s ON
For the middle button, I want a custom action, and I also want a middle button hold action
For the lower button - raises brightness to both lamps, but I want to make it so that when a lamp brightness is above 15 brightness points (out of 255) then the step is 8 points. If the brightness is below 15, then the step is 2 points.
For the off button - Toggles both off
I created this blueprint but I am having a hard time making it work… If anyone feels like taking a look!
blueprint:
name: Custom Lutron Pico 5 - Dual Lamp Control
description: >
Control two lamps with a Lutron Pico 5 Button remote, with custom logic for brightness adjustments and extended functionality for the middle button.
domain: automation
input:
pico_1:
description: Pico remote to associate with light entity.
selector:
device:
model: PJ2-3BRL-GXX-X01 (Pico3ButtonRaiseLower)
multiple: false
lamp_entity_1:
name: First Lamp Entity
description: First lamp entity to control.
selector:
entity:
domain: light
lamp_entity_2:
name: Second Lamp Entity
description: Second lamp entity to control.
selector:
entity:
domain: light
on_transition:
name: On Transition Duration
description: Duration in seconds for the lamps to transition on.
selector:
number:
min: 0
max: 15
unit_of_measurement: seconds
mode: slider
step: 1
default: 1
off_transition:
name: Off Transition Duration
description: Duration in seconds for the lamps to transition off.
selector:
number:
min: 0
max: 15
mode: slider
step: 1
default: 2
middle_button_action:
name: Middle Button Single Press Action
description: Action to execute when the middle button is pressed.
selector:
action: {}
middle_button_hold:
name: Middle Button Hold Action
description: Actions to execute when the middle button is held.
selector:
action: {}
hold_duration:
description: Duration in seconds to hold the middle button before the action takes place.
selector:
number:
min: 1
max: 10
mode: slider
step: 1
default: 3
- platform: device
device_id: !input pico_1
domain: lutron_caseta
type: press
subtype: "on"
- platform: device
type: press
subtype: "off"
- platform: device
type: press
subtype: "raise"
- platform: device
type: release
subtype: "raise"
- platform: device
type: press
subtype: "lower"
- platform: device
type: release
subtype: "lower"
- platform: device
type: press
subtype: "middle"
- platform: device
type: hold
subtype: "middle"
- choose:
- conditions:
- condition: trigger
sequence:
- service: light.turn_on
transition: !input on_transition
entity_id:
- !input lamp_entity_1
- !input lamp_entity_2
- conditions:
sequence:
- service: light.turn_off
transition: !input off_transition
entity_id:
- conditions:
sequence:
- repeat:
while:
- condition: state
entity_id: !input pico_1
state: 'on'
sequence:
- choose:
- conditions:
- condition: state
entity_id: !input lamp_entity_1
state: 'on'
sequence:
brightness_step_pct: 2
- conditions:
- condition: state
entity_id: !input lamp_entity_2
state: 'on'
sequence:
- delay: 100ms
- conditions:
sequence:
- repeat:
while:
- condition: state
state: 'on'
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
brightness_step_pct: -2
- conditions:
- condition: state
state: 'on'
sequence:
- delay: 100ms
- conditions:
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ middle_button_action != none }}"
sequence: !input middle_button_action
default:
brightness_pct: 80
kelvin: 2700
entity_id:
- conditions:
sequence:
- delay:
seconds: !input hold_duration
- choose:
- conditions:
value_template: "{{ middle_button_hold != none }}"
sequence: !input middle_button_hold
mode: restart
