Hi, I have installed the Broadlink integration for my RM4-Pro. However while I can see the remote in my main Home Assistant interface, I cannot see or control any of the devices associated with it.
Could someone please explain how I use the RM4-Pro/Broadlink integration in Home Assistant to trigger/turn a device on/off?
Hi did you figure it out ? I have same problem I see Broadlink in HA but none of the devices I have set up. Documentation seems to say remotes within broadlink should appear as entities but it is not.
