I was hoping someone could help I have 3 helpers setup for my tariffs:
Peak
Off-Peak
Super Off-Peak
They are calculating fine in the energy dashboard and switching between the 3 based on a time automation. In the energy dashboard I can set a fixed cost per tariff and the total is calculated there properly in dollars.
What I was hoping to do though is have a card that showed the daily and monthly running costs in realtime. I tried to do this with the sensor template but not to much luck.
I would assume I need to add up all 3 tariffs individually and * each by there respective kwh/rate. I wish homeassistant made the $ amount in the energy dashboard a sensor you could use elsewhere in the UI
For example ( off peak * price) + (peak * price) + (super off-peak * price)
