Hello, I have a lot shelly 1pm and tasmota, they show me the power consume per sensor, I want to calculate all the sensors together and its show me what the current energy/W/KW all of sensors together.
can I use a template? I try to do this but I did not succeed.
someone can tell me what I need to do?
Thank you
Yes you can use a template sensor. Share what you have tried (correctly formatted).
I erase all what I saw in forums , Nothing worked .
which template i need to use?
How would we know?
We donโt even know what your entity ids are.
ok. this is my sensors
I want to calculate all of this entities to one sensor that showing me the current energy
Please donโt post pictures of text. Post the entity ids.
I can change it later It does not matter so much what will be written but okโฆ
I need to add more anyway. so this is example for my sensors. I will add more sensors later, I dont need you write me all my sensors
thank you
sensor.shelly1pm_98cdac1e2174_power
sensor.shelly1pm_e8db84d7a30e_power
sensor.shelly1pm_84cca8a824e8_power
sensor.shelly1pm_c45bbe6c4171_power
"{{ states('sensor.shelly1pm_98cdac1e2174_power')|float(0) + states('sensor.shelly1pm_e8db84d7a30e_power')|float(0) + states('sensor.shelly1pm_84cca8a824e8_power')|float(0) + states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) }}"
Thank you man! its working!
maybe you know if can I Delete the numbers after dot?
and can I use it in history graph on lovelace?
and maybe you know if I can add โWโ to template?
thank you!!
Please share your full sensor configuration.
Thank you!
template:
- sensor:
- name: "ืฆืจืืืช ืืฉืื ื ืืืืืช"
state: >
"{{ states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) + states('sensor.shelly1pm_d8bfc01a1512_power')|float(0) + states('sensor.shelly1pm_84cca8a824e8_power')|float(0) + states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) + states('sensor.shelly1pm_98cdac1f5218_power')|float(0) + states('sensor.shelly1pm_e8db84d79a44_power')|float(0) + states('sensor.shelly1pm_98cdac1e2174_power')|float(0) + states('sensor.tasmota_energy_power')|float(0) + states('sensor.shelly1pm_e8db84d7a30e_power')|float(0) + states('sensor.tasmota_energy_power_3')|float(0) + states('sensor.shelly1pm_e8db84d79a44_power')|float(0) + states('sensor.tasmota_energy_power')|float(0) + states('sensor.sonoff_1000cab798_power')|float(0) + states('sensor.sonoff_1000cab589_power')|float(0) + states('sensor.tnvr_mqlkht_power')|float(0) + states('sensor.tasmota_energy_power_4')|float(0) }}"
template:
- sensor:
unit_of_measurement: 'W'
state_class: measurement
device_class: power
state: >
"{{ ( states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) + states('sensor.shelly1pm_d8bfc01a1512_power')|float(0) + states('sensor.shelly1pm_84cca8a824e8_power')|float(0) + states('sensor.shelly1pm_c45bbe6c4171_power')|float(0) + states('sensor.shelly1pm_98cdac1f5218_power')|float(0) + states('sensor.shelly1pm_e8db84d79a44_power')|float(0) + states('sensor.shelly1pm_98cdac1e2174_power')|float(0) + states('sensor.tasmota_energy_power')|float(0) + states('sensor.shelly1pm_e8db84d7a30e_power')|float(0) + states('sensor.tasmota_energy_power_3')|float(0) + states('sensor.shelly1pm_e8db84d79a44_power')|float(0) + states('sensor.tasmota_energy_power')|float(0) + states('sensor.sonoff_1000cab798_power')|float(0) + states('sensor.sonoff_1000cab589_power')|float(0) + states('sensor.tnvr_mqlkht_power')|float(0) + states('sensor.tasmota_energy_power_4')|float(0) )|round(0)|int(0) }}"
thank you!
you are the king
