Help with changing icon colors
I googled and found a lot of helpful articles but unfortunately none of them worked. I made my garage door work by using a zigbee relay that triggers a remote control. I then created a template cover in the configuration.yaml file. It shows up in my UI card and everything works. I can open and close the garage doors with no issue. I want to change the color of the icon when the door is open. When closed, it’s blue (which is fine), when it’s open, it’s purple. I want to change it to red. How do I do it? I googled and tried all different ways and nothing works. I also found an article where you can change it in the default theme file (I think it’s called ha-style.ts), but where is that? I’m not new to Home Assistant, but I feel like I get things working, and when I need to modify something, i forget a lot of what I previously learned. This shouldn’t be that hard to do. So here is my configuration.yaml file. This is the latest thing i tried.
frontend:
  themes:
    my_theme:
      state-cover-garage-open-color: "#ff0000"
Supposedly it overrides the default theme and changes the color of the cover entities.
I looked at this thread:
and tried a bunch of stuff listed in there as well
configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensor.yaml
binary_sensor: !include binary_sensor.yaml
notify: !include notify.yaml
#discovery:
homeassistant:
  customize: !include customize.yaml
  packages: !include_dir_named packages
frontend:
  themes:
    my_theme:
input_number:
  weatheralerts_notify_timeout:
    name: Weather Alerts Notify Timeout
    mode: slider
    initial: 900
    min: 60
    max: 3600
    step: 60
    icon: mdi:timer
    unit_of_measurement: "seconds"
command_line:
  - sensor:
      command: "cat /sys/class/thermal/thermal_zone0/temp"
      unit_of_measurement: "°C"
      value_template: '{{ value | multiply(0.001) | round(2)  }}'
cover:
    covers:
      dave_garage_door:
        device_class: garage
        friendly_name: "Dave's Garage Door"
        value_template: "{{ is_state('binary_sensor.daves_overhead_sensor_state', 'on') }}"
        open_cover:
          - condition: state
            entity_id: binary_sensor.daves_overhead_sensor_state
            state: "off"
          - action: light.turn_on
              entity_id: light.attached_garage_daves_side
        close_cover:
          - condition: state
            state: "on"
        icon_template: "{% if not is_state('binary_sensor.daves_overhead_sensor_state', 'off') %}mdi:garage-open{% else %}mdi:garage{% endif %}"
    covers:
      katie_garage_door:
        friendly_name: "Katie's Garage Door"
        value_template: "{{ is_state('binary_sensor.katie_overhead_door', 'on') }}"
        open_cover:
          - condition: state
            entity_id: binary_sensor.katie_overhead_door
            state: "off"
              entity_id: light.attached_garage_katies_side
        close_cover:
          - condition: state
            state: "on"
        icon_template: "{% if not is_state('binary_sensor.katie_overhead_door', 'off') %}mdi:garage-open{% else %}mdi:garage{% endif %}"
