I am trying to control a heater with a fairly complex setup. The power switch for this setup must pulse twice for about 1 second to turn on, and pulse once for about 5 seconds to turn off.
I have achieved this is esphome with the following code.
The problem I am now facing is controlling this via the “generic thermostat” integration and using the better-thermostat ui card.
The problem im having is
The entitty does not turn off, when dragging the tempreature above the target target temp, it is switch the entity on, pulsing twice.
However, when dragging the tempreature below the target tempreature, it does not turn the entity on, Pulse once for 5 seconds.
Also, when the tempreate is just left and it does not seem to be any significant changes, the entity just keeps switching on, pulsing twice per second even when there is no change. Is this normal behavior for the generic thermostat or even the better-thermostat UI? It seems to be turning ON every 5 minutes even when already ON.
climate:
- platform: generic_thermostat
heater: switch.heater_control_heater_power
target_sensor: sensor.heater_control_camper_temperature
ac_mode: false
- platform: dallas
address: 0xa85e61b81e64ff28
name: "Camper Temperature"
switch:
turn_on_action:
- switch.turn_on: heaterpower
- delay: 1s
- switch.turn_off: heaterpower
- delay: 1s
- delay: 1s
- delay: 1s
turn_off_action:
then:
- delay: 5s
- delay: 1s
- platform: gpio
pin: GPIO5
internal: true
type: custom:better-thermostat-ui-card
entity: climate.camper
disable_window: true
disable_off: false
disable_buttons: false
disable_heat: false
set_current_as_main: false
eco_temperature: 22
disable_battery_warning: true
disable_menu: false
disable_summer: true
disable_eco: true
Any ideas?
