I am working on an ESP32 project. I am replacing Truma’s ultraheat control and replacing it with an ESP 32 and an SSM1306 Display. I’m happy to share blueprints/hardware if anyone else is interested.
I would need help with 2 things. I dont think it’s that hard, but i’m stuck.
( relay 1-3 is pulled by differences in temperature.)
First:
(conditions below Dallas)
I would like the conditions for 1000w to only run if also GPIO16 (id= activate1kw) is true.
The condition for 2000W only if also the condition for 2000W GPIO23 (id= activate2kw) and GPIO16 (id= activate1kw) is true
next thing:
(Binary sensor)
If GPIO 25 id= turnoff is false, i wont all three relays to turn off, and i want them off untill GPIO25 is true
Plz help me
captive_portal:
web_server:
port: 80
auth:
username: admin
password: '123456'
button:
- platform: restart
icon: "mdi:emoticon-outline"
dallas:
- pin: 13
#update_interval: 120s
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "Signal %"
device_class: ""
- platform: uptime # Uptime
- platform: dallas
dallas_id: hub_1
address: 0x5474ddbf0a646128
on_value_range:
# Turn Off Heaters
- above: !lambda "return id(set_temp).state + 0.5;"
then:
- switch.turn_off: relay_1
- switch.turn_off: relay_2
- switch.turn_off: relay_3
# This combination gives 500W of power
- below: !lambda "return id(set_temp).state - 0.5;"
then:
- switch.turn_on: relay_2
- switch.turn_on: relay_3
# This combination gives 1000W of power
- below: !lambda "return id(set_temp).state - 1.5;"
then:
# This combination gives 2000W of power
- below: !lambda "return id(set_temp).state - 2.5;"
then:
- switch.turn_on: relay_1
binary_sensor:
# increase temp 0,5
- platform: gpio
pin:
number: 4
inverted: false
mode:
input: true
pullup: true
name: "increase temperature"
on_press:
then:
- number.operation:
operation: !lambda "return NUMBER_OP_INCREMENT;"
cycle: !lambda "return true;"
# Decrease temp 0,5
- platform: gpio
pin:
number: 17
inverted: false
mode:
input: true
pullup: true
name: "reduce temperature"
on_press:
then:
- number.operation:
operation: !lambda "return NUMBER_OP_DECREMENT;"
# Ok to start relays for 1000W
- platform: gpio
pin:
number: 16
inverted: false
mode:
input: true
pullup: true
# Ok to start relays for 2000W
- platform: gpio
pin:
number: 23
inverted: false
mode:
input: true
pullup: true
# Turn relay 1-3 off and keep them off
- platform: gpio
pin:
number: 25
inverted: false
mode:
input: true
pullup: true
switch:
- platform: gpio
pin:
number: 18
mode:
output: true
device_class: Switch
# restore_mode: restore_default_off
- platform: gpio
pin:
number: 19
mode:
output: true
- platform: gpio
pin:
number: 20
mode:
output: true
number:
name: "Vald temperatur"
device_class: temperature
optimistic: true
restore_value: true
min_value: 0
max_value: 100
step: 0.5
initial_value: 21.0
i2c:
sda: 21
scl: 22
scan: True
frequency: 400kHz
font:
- file: 'slkscr.ttf'
- file: 'bebas-neue-regular.ttf'
- file: 'arial.ttf'
display:
- platform: ssd1306_i2c
model: "SH1106 128x64"
reset_pin: 0
address: 0x3C
#update_interval: 2s
lambda: |-
// Print "Truma Heat"
it.printf(64, 0, id(font1), TextAlign::TOP_CENTER, "Tolycke 6");
// Temp:"
it.printf(10, 23, id(font3), TextAlign::TOP_LEFT, "Temp:");
// Print inside temperature (from homeassistant sensor)
if (id(temp).has_state()) {
it.printf(127, 23, id(font3), TextAlign::TOP_RIGHT , "%.1f°", id(temp).state);
// Temp Setp:"
it.printf(10, 60, id(font3), TextAlign::BASELINE_LEFT, "Temp Setp:");
// Print outside temperature (from homeassistant sensor)
if (id(set_temp).has_state()) {
it.printf(127, 60, id(font3), TextAlign::BASELINE_RIGHT , "%.1f°", id(set_temp).state);
