StefanoGiu
(Stefano Giugliano)
1
Hi all, I’ve created my own command_line json sensor that uses face_recognition service and compare it with rtsp snapshot from my surveillance camera.
It works properly and it stores also the link of the last snapshot of a face detection.
Now my question is…
is it possible to display the last known status of the sensor instead of unknown when no face is detected?
When I detect a face --> I generate a json output
When I don’t detect a face --> I generate no output
tom_l
2
Yes.
Create a template sensor that only updates if the state is not “unknown”. e.g.
sensors:
new_sensor:
value_template: >
{% if is_state('sensor.your_existing_sensor', 'unknown') %}
{{ states('sensor.new_sensor') }}
{% else %}
{{ states('sensor.your_existing_sensor') }}
{% endif %}
StefanoGiu
(Stefano Giugliano)
3
Thanks for the prompt reply.
This is my original sensor. If I use a template sensor, will it copy all the attributes?
- platform: command_line
name: Face Veranda 2
json_attributes:
- Faccia1
- Faccia2
- Faccia3
- Faccia4
- Faccia5
- Faccia6
- Faccia7
- Faccia8
- Persone
- FacceTotali
- Data
- File
command: 'python C:\GoogleHome\Python\CameraFaceDetection.py Veranda2 rtsp://admin:[email protected]:14000/tcp/av0_0'
value_template: '{{ value_json.Stato }}'
scan_interval: 10
command_timeout: 120
tom_l
4
No, only the state, you didn’t ask about attributes, only the state so that’s all my answer contains.
StefanoGiu
(Stefano Giugliano)
5
Got it. What about the attributes? I want to mantain the latest when the status was not unknown
tom_l
6
StefanoGiu
(Stefano Giugliano)
7
Something like this?
attribute_templates:
faccia1: >-
{{ state_attr('sensor.new_sensor','faccia1') }}
{% else %}
{{ state_attr('sensor.your_existing_sensor','faccia1') }}
{% endif %}
tom_l
8
Yep. You got it (the indentation is usually only 2 spaces though).
StefanoGiu
(Stefano Giugliano)
10
It works like a charm!!! Thanks @tom_l
StefanoGiu
(Stefano Giugliano)
11
One thing… when I restart HA, the values of the template sensors are lost… is there a way to keep them?
