Hello. I’m trying but failing miserably to follow the example below to check if my light entity is part of the “manual control” attribute of adaptive lighting. I like help converting my example to use as a condition in an automation. Testing in dev tools currently
Enity ID with attribute “manual control”:
switch.adaptive_lighting_island
My test in template editor just says “trigger” not defined
value_template: "{{ trigger.event.data.light.breakfast in state_attr (trigger.event.data.switch, 'manual control') }}"
Example:
‘alias: "Adaptive lighting: reset manual_control after 1 hour"
mode: parallel
platform: event
event_type: adaptive_lighting.manual_control
variables:
light: "{{ trigger.event.data.entity_id }}"
switch: "{{ trigger.event.data.switch }}"
- delay: "01:00:00"
- condition: template
value_template: "{{ light in state_attr(switch, 'manual_control') }}"
- service: adaptive_lighting.set_manual_control
entity_id: "{{ switch }}"
lights: "{{ light }}"
manual_control: false
