I’m in the process of automating the Speedtest component, but due to the QoS settings on my router, I don’t want it to run if someone is streaming anything because the results will be inaccurate. So I’m trying to use the state of my Harmony hubs to determine if a streaming activity is active. As near as I can tell from the documentation, and from other questions here on the forum, this should work, but it doesn’t. Am I missing something really obvious here?
(Don’t mind the quick cycle time or the fact that it’s turning on a switch, those are just for testing"
- action:
- data:
entity_id: switch.garage_door
service: switch.turn_on
alias: Speedtest
condition:
condition: or
conditions:
- condition: template
value_template: "{{ states.remote.tv_room.attributes.current_activity != 'Watch Fire TV' }}"
value_template: "{{ states.remote.moms_tv.attributes.current_activity != 'Watch Fire TV' }}"
platform: time
minutes: '/1'
seconds: '00'
If I just use a single value_template as the condition, it works fine. It’s just when I try to use two devices with ‘or’ logic.
