Help with Config Error (invalid entity ID)
Hi all,
I’m running into an issue getting a script to pass the validation, for some reason it keeps throwing an error in the logs and I can’t figure out why, especially since there is another variable entity in the script it seems to have no issue with.
Automation (no errors):
- alias: Lights auto on
  mode: parallel
  max: 9
  max_exceeded: silent
    - platform: state
      entity_id: binary_sensor.back_door
      to: 'on'
    - platform: state
      entity_id: binary_sensor.front_door
      to: 'on'
    - platform: state
      entity_id: binary_sensor.ranch_slider
      to: 'on'
  condition:
    - condition: or
      conditions:
      - condition: state
        entity_id: input_boolean.night_mode
        state: 'on'
      - condition: state
        entity_id: input_boolean.sunset_mode
        state: 'on'
    - service: script.autodoorlight
      data_template:
        door: "{{ trigger.entity_id }}"
        light: "{{ trigger.entity_id.split('.')[1] }}"
Script:
autodoorlight:
  alias: Door Light Auto on
  variables:
    on_light: 'light.{{ light }}'
  sequence:
    - choose:
      - conditions:
        - condition: state
          entity_id: "{{ on_light }}"
          state: "unavailable"
        sequence:
          - service: script.notification
              notify_service: notify.user_mobile_devices
              message: "{{ door.attributes.friendly_name }} light is turned off, please turn me on \uD83D\uDCA1"
      default:
        - service: light.turn_on
        - wait_for_trigger:
            platform: state
            entity_id: "{{ door }}"
            to: "off"
            for:
              seconds: 30
          timeout:
            minutes: 5
          continue_on_timeout: true
        - service: light.turn_off
Cannot for the life of me figure out why it is ok with the door variable and not the on_light variable. I’ve even done it so the automations sends the whole entity, i.e. light.front_door. Script still throws an error in the logs.
Any help here would be really appreciated.
I’m not sure, but is it possible, to use two “templated” entries in a row? First you use a template/variable to get to the on_light. And later on you use this templated entry again. Something rings a bell (but a very small one) that you can’t use it that way. But there is a good chance, that I confuse this with something else, sorry. :slight_smile:
Maybe you try it “directly” and see if it works:
autodoorlight:
  sequence:
    - choose:
      - conditions:
        - condition: state
          entity_id: "light.{{ light }}"
Just tried this:
Automation:
      data_template:
        open: "{{ trigger.entity_id.split('.')[1] }}"
Script:
- choose:
   - conditions:
     - condition: state
       entity_id: "light.{{ open }}"
Exact same issue:
Invalid config for [script]: Entity ID light.{{ open }} is an invalid entity ID for dictionary value @ data[‘sequence’][0][‘choose’][0][‘conditions’][0][‘entity_id’]. Got None not a valid value for dictionary value @ data[‘sequence’][0][‘default’][0][‘entity_id’]. Got None. (See /config/configuration.yaml, line 219).
I don’t think you can use a template for entity_id of a state condition.
Just use a template condition.
It is throwing the same error for the above portion too though.
Yet it seems to have no issue with the this portion:
platform: state
to: "off"
You can’t template a trigger entity_id
Just make a template trigger instead
wait_for_trigger:
  platform: template
  value_template: >
    {{ is_state(door, 'off') }}
And for your service, if you want to template entity_id, it needs to go in target or data. It can’t be outside
Reduced version of your automation:
  mode: parallel
  max: 9
    - platform: state
      entity_id:
        - binary_sensor.back_door
        - binary_sensor.front_door
        - binary_sensor.ranch_slider
      to: 'on'
  condition: "{{ is_state('input_boolean.night_mode', 'on') or is_state('input_boolean.sunset_mode', 'on') }}"
        light: "{{ trigger.to_state.object_id }}"
Revised version of your script:
autodoorlight:
  variables:
  sequence:
    - choose:
        - conditions: "{{ is_state(on_light, 'unavailable') }}"
          sequence:
                message: "{{ state_attr(door, 'friendly_name') }} light is turned off, please turn me on \uD83D\uDCA1"
      default:
        - wait_for_trigger:
              value_template: "{{ is_state(door, 'off') }}"
              for:
                seconds: 30
          timeout:
            minutes: 5
EDIT
Corrections. See petro’s post below.
Thank you very much, that is definately in the right direction. Getting the error for the condition in the script though:
Invalid config for [script]: Expected a dictionary @ data[‘sequence’][0][‘choose’][0][‘conditions’][0]. Got None.
Post above has been updated to include the corrections.
There’s more errors in your script. You have to use state_attr to get information from an entity_id.
this is wrong, it should be
Also, you have syntax errors in your condition.
That should be
notice the missing ) ?
Thanks for the corrections! I didn’t pay close attention when I revised the script.
I was on mobile when i first replied… missed them all too
I should have noticed the missing bracket too. :man_facepalming:
I wasn’t sure about the friendly name either, but was going to sort that once the light variable issue was sorted.
All tested and working brilliantly, thank you very much :slight_smile:
If you want to post the full piece up I will mark it as a solution.
You can do it, just paste what you got and mark it as a solution.
FWIW, the version I posted above contains the two corrections petro supplied.
