Help with configuring a Paulmann Zigbee lamp with an IKEA switch
Hello everyone,
I’m pretty new to Home Assistant and I apologize if I’m asking a perhaps trivial question here.
I have questions about the Zigbee2MQTT configuration.
I would like to control my Paulmann lamp Paulmann 50064 control via MQTT | Zigbee2MQTT with the IKEA switch IKEA E2001/E2002 control via MQTT | Zigbee2MQTT.
I use the Blueprint Controller - IKEA E2001/E2002 STYRBAR Remote control for this.
I’ve managed to switch it on and off. Brighter and darker doesn’t quite work. I would like to increase or decrease the brightness/darkness until I release the long press. Then the brightness should be maintained. Also, at the moment, if I reduce the brightness, the lamp eventually goes off. I want the brightness to stop at the darkest mode.
I can’t find the settings for the device’s action to make the color temperature warmer/colder.
Thank you very much for your help
