How would I configure the button, relay, and LED on this outlet to an ESPHome configuration?
I am just started with ESPHome, so I might be off, but here are my guesses.
Button: GPIO Binary Sensor
LED: Status LED Light
Relay: GPIO Switch
And of course a few Core elements, like wifi/network, logger and so on.
Thanks! I am just a little confused about which pin maps to which component.
The dropdown menus in your picture tells it
That was easy enough. Thank you!
Final question: how can I access the API directly using curl? I can’t seem to find the proper way to specify the API password.
