I would like this too. Maybe the home assistant scrape cant handle the advanced website for displaying the stats. Maybe if we find a simpler site that has the same data?
No, i found nothing
That site was so nice, I just created an iframe card with the link to the website, then set it to Panel mode in Lovelace to fill the screen in Home Assistant, and set the icon to mdi:biohazard.
type: iframe
url: >-
https://gisanddata.maps.arcgis.com/apps/opsdashboard/index.html#/bda7594740fd40299423467b48e9ecf6
aspect_ratio: 0%
have now done it via api for AUSTRIA
### CORONA Virus ###
- platform: rest
resource: "https://services1.arcgis.com/0MSEUqKaxRlEPj5g/arcgis/rest/services/ncov_cases/FeatureServer/1/query?f=json&where=(Confirmed%20%3E%200)%20AND%20(Country_Region%3D%27Austria%27)&returnGeometry=false&spatialRel=esriSpatialRelIntersects&outFields=*&orderByFields=Confirmed%20desc%2CCountry_Region%20asc%2CProvince_State%20asc&outSR=102100&resultOffset=0&resultRecordCount=250&cacheHint=true"
name: Corona Virus Erkrankt
value_template: "{{ value_json.features[0].attributes.Confirmed }}"
- platform: rest
name: Corona Virus Tote
value_template: "{{ value_json.features[0].attributes.Deaths }}"
- platform: rest
name: Corona Virus Geheilt
value_template: "{{ value_json.features[0].attributes.Recovered }}"
- platform: rest
name: Corona Virus letztes Update
value_template: "{{ value_json.features[0].attributes.Last_Update |replace ('000', '') | int | timestamp_custom('%H:%M %d.%m.%Y')}}"
automation:
- alias: Corona Virus
- entity_id: sensor.corona_virus_erkrankt
platform: numeric_state
above: 0
- service: telegram_bot.send_message
data_template:
parse_mode: markdown
- xxxxxxxxxxxxxxxxxxxxx
title: "-🦠-😷 CORONA Virus 😷-🦠-"
message: "Es sind {{ states('sensor.corona_virus_erkrankt') }} Personen in Österreich bestätigt! \n
\n
letztes Update: {{ states('sensor.corona_virus_letztes_update') }}\n
Tote: {{ states('sensor.corona_virus_tote') }}\n
Geheilt: {{ states('sensor.corona_virus_geheilt') }}\n
\n
Weitere Infos: \n
https://www.arcgis.com/apps/opsdashboard/index.html#/85320e2ea5424dfaaa75ae62e5c06e61"
Lovelace:
- type: custom:vertical-stack-in-card
cards:
- type: entities
entities:
- type: custom:text-divider-row
text: Corona - Virus
- entity: sensor.corona_virus_letztes_update
type: custom:multiple-entity-row
name: Corona Virus Infos
icon: mdi:bug-outline
show_state: false
#secondary_info: last-changed
entities:
- entity: sensor.corona_virus_erkrankt
- entity: sensor.corona_virus_geheilt
- entity: sensor.corona_virus_tote
icon: mdi:update
Thanks for this!
One thing, your fetching the api 4 times on every update interval.
With json_attributes you can do all in one sensor. (Germany here)
- platform: rest
resource: "https://services1.arcgis.com/0MSEUqKaxRlEPj5g/arcgis/rest/services/ncov_cases/FeatureServer/1/query?f=json&where=(Confirmed%20%3E%200)%20AND%20(Country_Region%3D%27Germany%27)&returnGeometry=false&spatialRel=esriSpatialRelIntersects&outFields=*&orderByFields=Confirmed%20desc%2CCountry_Region%20asc%2CProvince_State%20asc&outSR=102100&resultOffset=0&resultRecordCount=250&cacheHint=true"
name: Corona Virus Germany
json_attributes_path: "$.features[0].attributes"
json_attributes:
- Deaths
- Recovered
- Last_Update
yes this is better, thanks
Thanks for posting these API calls. For the US, the result set is a little different and returns results by each state and location. I created these calls for the US and one for North Carolina, US.
# Corona Virus Statistics
- platform: rest
resource: "https://services1.arcgis.com/0MSEUqKaxRlEPj5g/arcgis/rest/services/ncov_cases/FeatureServer/1/query?f=json&where=(Country_Region%3D%27US%27)&outStatistics=%5B%7B%22statisticType%22%3A%22sum%22%2C%22onStatisticField%22%3A%22Confirmed%22%2C%22outStatisticFieldName%22%3A%22Confirmed%22%7D%2C%20%7B%22statisticType%22%3A%22sum%22%2C%22onStatisticField%22%3A%22Deaths%22%2C%22outStatisticFieldName%22%3A%22Deaths%22%7D%2C%20%7B%22statisticType%22%3A%22sum%22%2C%22onStatisticField%22%3A%22Recovered%22%2C%22outStatisticFieldName%22%3A%22Recovered%22%7D%5D"
name: Corona Virus US
json_attributes:
- Confirmed
- Deaths
- Recovered
- platform: rest
resource: "https://services1.arcgis.com/0MSEUqKaxRlEPj5g/arcgis/rest/services/ncov_cases/FeatureServer/1/query?f=json&where=(Country_Region%3D%27US%27)%20AND%20(Province_State%20LIKE%20%27%25NC%27)&outStatistics=%5B%7B%22statisticType%22%3A%22sum%22%2C%22onStatisticField%22%3A%22Confirmed%22%2C%22outStatisticFieldName%22%3A%22Confirmed%22%7D%2C%20%7B%22statisticType%22%3A%22sum%22%2C%22onStatisticField%22%3A%22Deaths%22%2C%22outStatisticFieldName%22%3A%22Deaths%22%7D%2C%20%7B%22statisticType%22%3A%22sum%22%2C%22onStatisticField%22%3A%22Recovered%22%2C%22outStatisticFieldName%22%3A%22Recovered%22%7D%5D"
name: Corona Virus North Carolina
json_attributes:
- Confirmed
- Deaths
- Recovered
For other states, change the state code in the URL above:
… (Province_State%20LIKE%20%27%25NC%27) …
As of March 1, 2020, there are no cases in NC, so it returns null results. I am not sure how to convert those nulls to zero. I’ll play around with it.
It looks like Home Assistant handles the Null json array value fine, so no need to convert to zero. It shows the value as None.
This is great! Worked for me! Now I’m trying to figure out how to get the number for world total too. I haven’t been able to figure it out yet.
Use this line for world:
resource: "https://services1.arcgis.com/0MSEUqKaxRlEPj5g/arcgis/rest/services/ncov_cases/FeatureServer/1/query?f=json&&outStatistics=%5B%7B%22statisticType%22%3A%22sum%22%2C%22onStatisticField%22%3A%22Confirmed%22%2C%22outStatisticFieldName%22%3A%22Confirmed%22%7D%2C%20%7B%22statisticType%22%3A%22sum%22%2C%22onStatisticField%22%3A%22Deaths%22%2C%22outStatisticFieldName%22%3A%22Deaths%22%7D%2C%20%7B%22statisticType%22%3A%22sum%22%2C%22onStatisticField%22%3A%22Recovered%22%2C%22outStatisticFieldName%22%3A%22Recovered%22%7D%5D"
- platform: rest
name: Corona Virus World
json_attributes:
- Confirmed
- Deaths
- Recovered
Thank you all, Now how do I display the Confirmed and Deaths, right now I’m only getting Recovered to display?
I created template sensors for use in Lovelace:
sensors:
corona_virus_us_confirmed:
value_template: "{{ state_attr('sensor.corona_virus_us', 'Confirmed') }}"
friendly_name: 'Corona Virus US Confirmed Cases'
sensors:
corona_virus_us_deaths:
value_template: "{{ state_attr('sensor.corona_virus_us', 'Deaths') }}"
friendly_name: 'Corona Virus US Deaths'
sensors:
corona_virus_us_recovered:
value_template: "{{ state_attr('sensor.corona_virus_us', 'Recovered') }}"
friendly_name: 'Corona Virus US Recovered'
Have you a solution to get the last updated attribute readable?
See my post up, i have it convertet
I don’t particularly like @Johann_Edelmuller’s method because it assumes that the updates happen on the exact second. There’s no guarentee that is true.
Using @Johann_Edelmuller’s method, the sensor should be
value_template: "{{ value_json.features[0].attributes.Last_Update | int / 1000 | timestamp_custom('%H:%M %d.%m.%Y') }}"
and @VDRainer’s for the same format on a template sensor:
value_template: >
{% set sensor = 'sensor.corona_virus_germany' %}
{{ state_attr(sensor, 'Last_Update') | int / 1000 | timestamp_custom('%H:%M %d.%m.%Y') }}"
As i didn’t want another template sensor i decided to put this value to the state of the sensor.
- platform: rest
resource: "https://services1.arcgis.com..."
value_template: "{{ (value_json.features[0].attributes.Last_Update / 1000) | int | timestamp_custom('%d.%m.%Y %H:%M') }}"
json_attributes:
- Confirmed
- Deaths
- Recovered
So now there’s everything in one sensor.
- type: entities
entities:
- type: 'custom:multiple-entity-row'
entity: sensor.corona_virus_germany
show_state: false
icon: 'mdi:biohazard'
style: |
:host {
--paper-item-icon-color: cyan;
entities:
- attribute: Confirmed
- attribute: Deaths
- attribute: Recovered
secondary_info:
FYI, if you go that route and use this template with device_class: timestamp
, the UI will perform all the fancy math to make it read x minutes ago
- platform: rest
value_template: "{{ (value_json.features[0].attributes.Last_Update / 1000) | int | timestamp_custom('%Y-%m-%dT%H:%M:%S.%f+00:00') }}"
json_attributes:
- Confirmed
- Deaths
- Recovered
