Help with correct MQTT trigger syntax in automation. I can’t write it in such a way that the automation only works when the button is pressed correctly. ::
When I don’t specify the payload, automation works, but I don’t know how to correctly indicate in the payload that I only need to press the switch key.
![image](https://community-assets.home-assistant.io/original/4X/0/0/9/0098c1d918a45422db71a66f0930c898afe090c7.png)
Tell me how to correctly write a trigger for the single left one in this case
Thanks in advance
