I’m trying to count how many ACs are on through a template.
Here is what I’ve got so far (quite new to this).
{% for state in states.climate %}
{% if is_state(‘climate???’, ‘off’) -%}
– here should come the counting–
{%- else -%}
{{state}}
{%- endif %}
{% endfor %}
Every device starts with climate.[name] and the I’m looking to count those that are not ‘off’.
Cany you please help with to modify it to work?
Thanks.
Here is the output I’m getting:
<template TemplateState(<state climate.noya=off; hvac_modes=[<HVACMode.COOL: ‘cool’>, <HVACMode.HEAT: ‘heat’>, <HVACMode.FAN_ONLY: ‘fan_only’>, <HVACMode.DRY: ‘dry’>, <HVACMode.HEAT_COOL: ‘heat_cool’>, <HVACMode.OFF: ‘off’>], min_temp=16, max_temp=30, target_temp_step=1, fan_modes=[‘low’, ‘medium’, ‘high’, ‘auto’, ‘strong’], swing_modes=[‘stopped’, ‘fixedtop’, ‘fixedmiddletop’, ‘fixedmiddle’, ‘fixedmiddlebottom’, ‘fixedbottom’, ‘rangetop’, ‘rangemiddle’, ‘rangebottom’, ‘rangefull’], current_temperature=25.1, temperature=23, current_humidity=68.9, fan_mode=high, swing_mode=stopped, friendly_name=2-ac-noya, supported_features=425 @ 2024-03-29T16:53:22.609583+03:00>)>
<template TemplateState(<state climate.guy=off; hvac_modes=[<HVACMode.COOL: 'cool'>, <HVACMode.HEAT: 'heat'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.DRY: 'dry'>, <HVACMode.HEAT_COOL: 'heat_cool'>, <HVACMode.OFF: 'off'>], min_temp=16, max_temp=30, target_temp_step=1, fan_modes=['low', 'medium', 'high', 'auto', 'strong'], swing_modes=['stopped', 'fixedtop', 'fixedmiddletop', 'fixedmiddle', 'fixedmiddlebottom', 'fixedbottom', 'rangetop', 'rangemiddle', 'rangebottom', 'rangefull'], current_temperature=24, temperature=30, current_humidity=68.5, fan_mode=auto, swing_mode=stopped, friendly_name=2-ac-guy, supported_features=425 @ 2024-03-27T15:38:16.064065+02:00>)>
<template TemplateState(<state climate.raz=off; hvac_modes=[<HVACMode.COOL: 'cool'>, <HVACMode.HEAT: 'heat'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.DRY: 'dry'>, <HVACMode.HEAT_COOL: 'heat_cool'>, <HVACMode.OFF: 'off'>], min_temp=16, max_temp=30, target_temp_step=1, fan_modes=['low', 'medium', 'high', 'auto', 'strong'], swing_modes=['stopped', 'fixedtop', 'fixedmiddletop', 'fixedmiddle', 'fixedmiddlebottom', 'fixedbottom', 'rangetop', 'rangemiddle', 'rangebottom', 'rangefull'], current_temperature=22.5, temperature=20, current_humidity=69.6, fan_mode=auto, swing_mode=stopped, friendly_name=2-ac-raz, supported_features=425 @ 2024-03-29T15:18:35.639643+03:00>)>
<template TemplateState(<state climate.parents=off; hvac_modes=[<HVACMode.COOL: 'cool'>, <HVACMode.HEAT: 'heat'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.DRY: 'dry'>, <HVACMode.HEAT_COOL: 'heat_cool'>, <HVACMode.OFF: 'off'>], min_temp=16, max_temp=30, target_temp_step=1, fan_modes=['low', 'medium', 'high', 'auto', 'strong'], swing_modes=['stopped', 'fixedtop', 'fixedmiddletop', 'fixedmiddle', 'fixedmiddlebottom', 'fixedbottom', 'rangetop', 'rangemiddle', 'rangebottom', 'rangefull'], current_temperature=24, temperature=22, current_humidity=70.8, fan_mode=auto, swing_mode=stopped, friendly_name=2-ac-parents, supported_features=425 @ 2024-03-29T09:28:24.321880+03:00>)>
Here is a list of the output I’m getting
