Help with cover template
I created a template for a cover. Home assistant is telling me that the position is unknown in my dashboard. This is the code that I have:
  covers:
    danielle_s_shades:
      friendly_name: Danielle's shade
      position_template: >-
          {% set p = 100 - (state_attr('cover.danielles_shades_window_covering', 'current_position') | int)%}
          {% if p > 11 %} p
          {% else %} 0
          {% endif %}
      open_cover:
        service: cover.open_cover
          entity_id: cover.danielles_shades_window_covering
      close_cover:
        service: cover.close_cover
      stop_cover:
        service: cover.stop_cover
      set_cover_position:
        service: cover.set_cover_position
          position: "{{ 100 - (position) }}"
What am I doing wrong?
You need to wrap the variable p in curly braces in the position template
          {% if p > 11 %}{{ p }}
          {% else %} 0
          {% endif %}
I don’t really use covers, but the following seems to be missing a definition for the position variable
According to the docs template covers can use the this variable, so your template should likely be:
set_cover_position:
  - service: cover.set_cover_position
      position: "{{ 100 - this.attributes.position }}"
