Help with current setup or advice on what to change
Hello every one.
Current I’m using the Synology NAS to run a container with HA and have this others running there also:
  • eclipse-mosquitto
  • wyoming-whisper
  • wyoming-openwakeword
  • wyoming-piper
And have a Raspberry PI 5 (4GB) with a WAVESHARE 26399 PoE HAT and a Touch Display 2 - 7
On the PI I have the Pi OS with the Touchkio that comunicates with HA on NAS with the eclipse-mosquitto that I setup in the NAS Container manager.
Have integrate all the wyomning into the HA already
Connected to the PI I have the M5Stack Atom Echo to give him power, but is connected to the ESPHome on the HA.
On the HA have also a Reolink doorbell, and wanted to use the Touchkio to answer the when people press the doorbell button, I can see already but needed to have a 2way audio strem with the PI, can I use the M5Stack Atom Echo or M5Stack Atom EchoS3R (thinking on getting for is better speaker) for it? And also for Voice Assistance?
Should I just install the HAOS direct into the PI and have everthing in there?
Wanted to use the HA to control the house and be my VA, but if you guys have better ideas for me, they are welcome, but don’t make me spend too much € hehe :stuck_out_tongue: I’m already at 300€ for this setup (have bougth 5 Shelly 2pm to control the shutter haven’t installed them at the moment)
If you do you will have problems using the:
I don’t think either one will work as the pi will have only CLI and I’ve seen people have problems with drivers for PI Hats inside HAOS.
Then by using like I have, can I still use the PI with the touchkio and have a 2way audio stream to the reolink doorbell?
Any one with the same problem or know the best solution for the setup that I have?
