Help with custom button-card with conditions using Java
Good morning.
In my custom button card:
state_display: |
    if (entity.state == 'off')
      return "Spenta";
    else
      if (entity.state == 'on')
        return "Accesa";
      else
        return "Non disponibile";
This working fine.
Why doesn’t this work?
state_display: |
    switch (entity.state)
      case 'off':
        return "Spenta";
      case 'on':
        return "Accesa";
      default:
Question n° 2
state_display: |
      return "Spenta";
    else
        return "Accesa";
      else
I need to manage not entity.state but
state_display: |
    if (states('input_boolean.lastricosolare_abilitazionepostazioneidroponica5') == 'off')
      return "Spenta";
    else
      if (states('input_boolean.lastricosolare_abilitazionepostazioneidroponica5') == 'on')
        return "Accesa";
      else
Is possible?
Question n° 3
In my dashboard I’ve created a master bottom that enables several other buttons and therefore inhibits their use if deactivated.
Currently the secondary buttons all have:
tap_action:
  action: toggle
If the master button is disabled, I need to transform it into:
tap_action:
  action: none
but from the documentation of the card it seems to me that I understand that the tap_action do not support javascript.
How can I fix?
Because you’re missing brackets.
    switch (entity.state) {
      case 'off':
        return "Spenta";
      case 'on':
        return "Accesa";
      default:
FYI this is javascript not java.
q2
states['input_boolean.lastricosolare_abilitazionepostazioneidroponica5'].state
q3 is not possible because you can’t template the tap action section.
Thanks for your attention.
You are always very quick and professional in your replies.
Excuse me but I need to understand one thing:
From custom button card manual:
The template rendering uses a special format. All the fields where template is supported also support plain text. To activate the templating feature for such a field, you’ll need to enclose the javascript function inside 3 square brackets: [[[ javascript function here ]]]
From W3school site:
if (condition) {
// block of code to be executed if the condition is true
Have brackets.
But:
state_display: |
      return "Spenta";
    else
        return "Accesa";
      else
Don’t have brackets and working.
From W3school site:
switch(expression) {
case x:
// code block
break;
case y:
// code block
break;
default:
// code block
Have brackets.
But:
state_display: |
      case 'off':
        return "Spenta";
      case 'on':
        return "Accesa";
      default:
without brackets not working
That’s a shorthand if statement. JS allows this on if statements, that doesn’t mean you can do that on a switch case.
Many tanks Petro!
Solution for q3 here
Hi, how do I insert a template in the custom_fields field?
I would need this template, to display a sentence based on the state of a sensor.
This is the template I would like to use:
{% if is_state('alarm_control_panel.alarmo', 'armed_home') %}
          The alarm is activated
 {% else %}
          Alarm off
 {% endif %}
This is the part of the button-card where I would like to insert it:
custom_fields:
  title: |
    ALARM
  title_2: |
    --> HERE <--
You can’t use jinja, you have to use JS. The template you posted is Jinja.
Thank you @petro for your reply, but unfortunately I don’t know how to use JS, I’ve always used Jinja. Can you help me?
Edit: I tried to make some attempts taking inspiration from the previous messages, but I always had errors
title_2: |
    if ('alarm_control_panel.alarmo.state' == 'armed_home')
      return "The alarm is activated";
    else
        return "Alarm off";
