Help with custom 'light' component - does not name a type
Hey folks. I really appreciate the help here.
I’m trying to get this library to work with ESPHome. I’m trying to follow GitHub - jesserockz/esphome-external-component-examples to create a custom component that calls the library.
Before I even started to import the library I wanted to get the basic “empty_light” example to work. So I have the following setup:
device.yaml
substitutions:
  device_name: office-test-1
esphome:
  platform: ESP32
  board: esp32dev
<<: !include .base-basic.yaml
external_components:
  - source:
      type: local
      path: custom_components
light:
  - platform: p9813_light
    output: pwm_output
output:
  - platform: ledc
    pin: GPIO19
    frequency: 1000 Hz
And I have three files created:
/config/esphome/custom_components/p9813_light/light.py
import esphome.codegen as cg
import esphome.config_validation as cv
from esphome.components import light, output
from esphome.const import CONF_OUTPUT_ID, CONF_OUTPUT
namespace = cg.esphome_ns.namespace('p9813_light')
P9813LightOutput = namespace.class_('P9813LightOutput', light.LightOutput)
CONFIG_SCHEMA = light.BRIGHTNESS_ONLY_LIGHT_SCHEMA.extend({
    cv.GenerateID(CONF_OUTPUT_ID): cv.declare_id(P9813LightOutput),
    cv.Required(CONF_OUTPUT): cv.use_id(output.FloatOutput)
def to_code(config):
    var = cg.new_Pvariable(config[CONF_OUTPUT_ID])
    yield light.register_light(var, config)
    out = yield cg.get_variable(config[CONF_OUTPUT])
    cg.add(var.set_output(out))
/config/esphome/custom_components/p9813_light/p9813_light.h
#pragma once
#include "esphome/core/component.h"
#include "esphome/components/output/float_output.h"
#include "esphome/components/light/light_output.h"
namespace esphome {
    namespace p9813_light {
        class P9813LightOutput : public light::LightOutput, public Component {
         public:
          void setup() override;
          light::LightTraits get_traits() override;
          void set_output(output::FloatOutput *output) { output_ = output; }
          void write_state(light::LightState *state) override;
          void dump_config() override;
         protected:
          output::FloatOutput *output_;
/config/esphome/custom_components/p9813_light/p9813_light.cpp
#include "esphome/core/log.h"
#include "p9813_light.h"
namespace esphome {
        static const char *TAG = "p9813_light.light";
        void P9813LightOutput::setup() {
        light::LightTraits P9813LightOutput::get_traits() {
            auto traits = light::LightTraits();
            traits.set_supports_brightness(true);
            traits.set_supports_rgb(false);
            traits.set_supports_rgb_white_value(false);
            traits.set_supports_color_temperature(false);
            return traits;
        void P9813LightOutput::write_state(light::LightState *state) {
        void P9813LightOutput::dump_config(){
            ESP_LOGCONFIG(TAG, "p9813 custom light");
When I compile I get:
src/main.cpp:37:1: error: 'p9813_light' does not name a type
 p9813_light::P9813LightOutput *p9813_light_p9813lightoutput;
/config/esphome/testing-1.yaml: In function 'void setup()':
/config/esphome/testing-1.yaml:236:3: error: 'p9813_light_p9813lightoutput' was not declared in this scope
/config/esphome/testing-1.yaml:236:38: error: 'p9813_light' does not name a type
*** [.pioenvs/h-office-test-1/src/main.cpp.o] Error 1
I keep thinking this is due to some typo I’ve made but I can’t spot it. Help?
Alright. After a day or so to come back to this fresh I made some progress.
First: you need a __init__.py file in the root of each custom component’s folder.
Second: set_supports_X is deprecated. Use traits.set_supported_color_modes({light::ColorMode::BRIGHTNESS}); (for example) instead.
