Hi all,
I have for 2 years a d1 mini sensor to report when the garage door is opened or closed. I don’t have many esp devices so I had to update the integration for 6+ months… After the update it stopped working as it should. For example when I am opening the door it goes from on to off several times and while the door is opened it reports it as closed.
I tried to reinstall it but it is not working as expected.
The code and the logs are the following.
Can someone help me please?
esphome:
platform: ESP8266
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "xxxx"
wifi:
ssid: "xxx-xxxx"
password: "xxxxx"
manual_ip:
static_ip: 192.168.1.xxx
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Garage-D1Mini Fallback Hotspot"
password: "xxxxx"
captive_portal:
binary_sensor:
- platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
name: "Garage Door d1mini"
filters:
delayed_on: 1000ms
device_class: door
INFO ESPHome 2024.4.1
INFO Reading configuration /config/esphome/garage-d1mini.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing garage-d1mini (board: d1_mini; framework: arduino; platform: platformio/[email protected])
Platform Manager: Installing platformio/espressif8266 @ 4.2.1
INFO Installing platformio/espressif8266 @ 4.2.1
Downloading [####################################] 100%
Unpacking [####################################] 100%
Platform Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Tool Manager: Installing platformio/framework-arduinoespressif8266 @ ~3.30102.0
INFO Installing platformio/framework-arduinoespressif8266 @ ~3.30102.0
Tool Manager: [email protected] has been installed!
Tool Manager: Installing platformio/tool-scons @ ~4.40600.0
INFO Installing platformio/tool-scons @ ~4.40600.0
Tool Manager: Removing tool-scons @ 4.40502.0
INFO Removing tool-scons @ 4.40502.0
Tool Manager: [email protected] has been removed!
INFO [email protected] has been removed!
Library Manager: Installing esphome/ESPAsyncTCP-esphome @ 2.0.0
INFO Installing esphome/ESPAsyncTCP-esphome @ 2.0.0
Library Manager: [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing ottowinter/ESPAsyncTCP-esphome
INFO Installing ottowinter/ESPAsyncTCP-esphome
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
Compiling .pioenvs/garage-d1mini/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/binary_sensor/automation.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/binary_sensor/binary_sensor.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/binary_sensor/filter.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/esp8266/core.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/esp8266/gpio.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/esp8266/preferences.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/gpio/binary_sensor/gpio_binary_sensor.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/logger/logger_esp32.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/logger/logger_esp8266.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/logger/logger_host.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/logger/logger_libretiny.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/logger/logger_rp2040.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/md5/md5.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/mdns/mdns_libretiny.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/ota/ota_backend_arduino_libretiny.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/ota/ota_component.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/socket/lwip_sockets_impl.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/wifi/wifi_component_libretiny.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/application.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/color.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/component.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/component_iterator.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/controller.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/entity_base.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/helpers.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/log.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/ring_buffer.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/scheduler.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/string_ref.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/time.cpp.o
Compiling .pioenvs/garage-d1mini/src/esphome/core/util.cpp.o
Compiling .pioenvs/garage-d1mini/src/main.cpp.o
Generating LD script .pioenvs/garage-d1mini/ld/local.eagle.app.v6.common.ld
Compiling .pioenvs/garage-d1mini/libbd1/ESPAsyncTCP-esphome/AsyncPrinter.cpp.o
Compiling .pioenvs/garage-d1mini/libbd1/ESPAsyncTCP-esphome/ESPAsyncTCP.cpp.o
Compiling .pioenvs/garage-d1mini/libbd1/ESPAsyncTCP-esphome/ESPAsyncTCPbuffer.cpp.o
Compiling .pioenvs/garage-d1mini/libbd1/ESPAsyncTCP-esphome/SyncClient.cpp.o
Compiling .pioenvs/garage-d1mini/libbd1/ESPAsyncTCP-esphome/tcp_axtls.c.o
Compiling .pioenvs/garage-d1mini/libaf0/Hash/Hash.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/BearSSLHelpers.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/CertStoreBearSSL.cpp.o
Archiving .pioenvs/garage-d1mini/libaf0/libHash.a
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/ESP8266WiFi.cpp.o
Archiving .pioenvs/garage-d1mini/libbd1/libESPAsyncTCP-esphome.a
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/ESP8266WiFiScan.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/WiFiClient.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/WiFiServer.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/WiFiUdp.cpp.o
Compiling .pioenvs/garage-d1mini/lib67b/ESP8266WiFi/enable_wifi_at_boot_time.cpp.o
Compiling .pioenvs/garage-d1mini/lib625/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling .pioenvs/garage-d1mini/lib625/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Compiling .pioenvs/garage-d1mini/lib625/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Archiving .pioenvs/garage-d1mini/lib67b/libESP8266WiFi.a
Compiling .pioenvs/garage-d1mini/lib625/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling .pioenvs/garage-d1mini/lib625/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling .pioenvs/garage-d1mini/lib625/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling .pioenvs/garage-d1mini/lib625/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling .pioenvs/garage-d1mini/libecb/DNSServer/DNSServer.cpp.o
Compiling .pioenvs/garage-d1mini/lib3ff/ESP8266mDNS/ESP8266mDNS.cpp.o
Archiving .pioenvs/garage-d1mini/libecb/libDNSServer.a
Compiling .pioenvs/garage-d1mini/lib3ff/ESP8266mDNS/LEAmDNS.cpp.o
Compiling .pioenvs/garage-d1mini/lib3ff/ESP8266mDNS/LEAmDNS_Control.cpp.o
Archiving .pioenvs/garage-d1mini/lib625/libESPAsyncWebServer-esphome.a
Compiling .pioenvs/garage-d1mini/lib3ff/ESP8266mDNS/LEAmDNS_Helpers.cpp.o
Compiling .pioenvs/garage-d1mini/lib3ff/ESP8266mDNS/LEAmDNS_Structs.cpp.o
Compiling .pioenvs/garage-d1mini/lib3ff/ESP8266mDNS/LEAmDNS_Transfer.cpp.o
Archiving .pioenvs/garage-d1mini/libFrameworkArduinoVariant.a
Compiling .pioenvs/garage-d1mini/FrameworkArduino/Crypto.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/Esp-frag.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/Esp-version.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/Esp.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/FS.cpp.o
Archiving .pioenvs/garage-d1mini/lib3ff/libESP8266mDNS.a
Compiling .pioenvs/garage-d1mini/FrameworkArduino/FSnoop.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/IPAddress.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/LwipDhcpServer-NonOS.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/LwipDhcpServer.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/LwipIntf.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/LwipIntfCB.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/Schedule.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/StackThunk.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/StreamSend.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/TypeConversion.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/Updater.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/abi.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/aes_unwrap.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/cont.S.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/cont_util.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_app_entry_noextra4k.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_eboot_command.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_features.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_flash_quirks.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_flash_utils.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_i2s.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_main.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_non32xfer.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_noniso.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_phy.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_postmortem.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_si2c.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_sigma_delta.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_spi_utils.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_timer.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_vm.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_waveform_phase.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_waveform_pwm.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_wiring.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_wiring_analog.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_wiring_digital.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_wiring_pulse.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_wiring_pwm.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/core_esp8266_wiring_shift.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/crc32.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/debug.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/exc-c-wrapper-handler.S.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/exc-sethandler.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/flash_hal.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/gdb_hooks.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/heap.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/hwdt_app_entry.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/libb64/cdecode.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/libb64/cencode.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/libc_replacements.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/mmu_iram.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/reboot_uart_dwnld.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/spiffs/spiffs_cache.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/spiffs/spiffs_check.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/spiffs/spiffs_gc.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/spiffs/spiffs_hydrogen.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/spiffs/spiffs_nucleus.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/spiffs_api.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/sqrt32.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/stdlib_noniso.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/time.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/uart.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/umm_malloc/umm_info.c.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/umm_malloc/umm_integrity.c.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/umm_malloc/umm_local.c.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/umm_malloc/umm_malloc.cpp.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/umm_malloc/umm_poison.c.o
Compiling .pioenvs/garage-d1mini/FrameworkArduino/wpa2_eap_patch.cpp.o
Archiving .pioenvs/garage-d1mini/libFrameworkArduino.a
Linking .pioenvs/garage-d1mini/firmware.elf
RAM: [==== ] 40.0% (used 32800 bytes from 81920 bytes)
Flash: [==== ] 39.2% (used 409853 bytes from 1044464 bytes)
Building .pioenvs/garage-d1mini/firmware.bin
esp8266_copy_factory_bin([".pioenvs/garage-d1mini/firmware.bin"], [".pioenvs/garage-d1mini/firmware.elf"])
========================= [SUCCESS] Took 78.58 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.1.xx
INFO Uploading /data/build/garage-d1mini/.pioenvs/garage-d1mini/firmware.bin (414000 bytes)
INFO Compressed to 291167 bytes
Uploading: [============================================================] 100% Done...
INFO Upload took 4.61 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.1.xx using esphome API
INFO Successfully connected to garage-d1mini @ 192.168.1.xx in 19.344s
INFO Successful handshake with garage-d1mini @ 192.168.1.xx in 0.021s
[19:57:37][I][app:100]: ESPHome version 2024.4.1 compiled on Apr 25 2024, 19:56:31
[19:57:37][C][wifi:580]: WiFi:
[19:57:37][C][wifi:408]: Local MAC: A4:CF:12:xx:FD:xx
[19:57:37][C][wifi:413]: SSID: 'xxxx-xxxx'[redacted]
[19:57:37][C][wifi:416]: IP Address: 192.168.1.xx
[19:57:37][C][wifi:419]: BSSID: D8:0D:17:EE:9C:xx[redacted]
[19:57:37][C][wifi:421]: Hostname: 'garage-d1mini'
[19:57:37][C][wifi:423]: Signal strength: -45 dB ▂▄▆█
[19:57:37][C][wifi:427]: Channel: 11
[19:57:37][C][wifi:428]: Subnet: 255.255.255.0
[19:57:37][C][wifi:429]: Gateway: 192.168.1.1
[19:57:37][C][wifi:430]: DNS1: 0.0.0.0
[19:57:37][C][wifi:431]: DNS2: 0.0.0.0
[19:57:37][C][logger:166]: Logger:
[19:57:37][C][logger:167]: Level: DEBUG
[19:57:37][C][logger:169]: Log Baud Rate: 115200
[19:57:37][C][logger:170]: Hardware UART: UART0
[19:57:37][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Garage Door d1mini'
[19:57:37][C][gpio.binary_sensor:015]: Device Class: 'door'
[19:57:37][C][gpio.binary_sensor:016]: Pin: GPIO12
[19:57:37][C][captive_portal:088]: Captive Portal:
[19:57:37][C][mdns:115]: mDNS:
[19:57:37][C][mdns:116]: Hostname: garage-d1mini
[19:57:37][C][ota:096]: Over-The-Air Updates:
[19:57:37][C][ota:097]: Address: 192.168.1.xx:8266
[19:57:37][C][ota:100]: Using Password.
[19:57:37][C][ota:103]: OTA version: 2.
[19:57:37][C][api:139]: API Server:
[19:57:37][C][api:140]: Address: 192.168.1.xx:6053
[19:57:37][C][api:144]: Using noise encryption: NO
[20:02:23][I][ota:117]: Boot seems successful, resetting boot loop counter.
[20:42:27][D][binary_sensor:036]: 'Garage Door d1mini': Sending state ON
[20:42:28][D][binary_sensor:036]: 'Garage Door d1mini': Sending state OFF
[20:42:46][D][binary_sensor:036]: 'Garage Door d1mini': Sending state ON
[20:42:46][D][binary_sensor:036]: 'Garage Door d1mini': Sending state OFF
[20:42:48][D][binary_sensor:036]: 'Garage Door d1mini': Sending state ON
[20:42:49][D][binary_sensor:036]: 'Garage Door d1mini': Sending state OFF
[20:42:57][D][binary_sensor:036]: 'Garage Door d1mini': Sending state ON
[20:42:57][D][binary_sensor:036]: 'Garage Door d1mini': Sending state OFF
[20:43:04][D][binary_sensor:036]: 'Garage Door d1mini': Sending state ON
[20:43:04][D][binary_sensor:036]: 'Garage Door d1mini': Sending state OFF
