Help with data_template using dynamic entity names question
Hi, you suggestions to others where of great help to me.
I’ve tried a bunch of code to be able to feed to the option image a variable instead of a url path
its supposed to be be like this:
image: "image/path"
I have a template variable that saves the changing url for the media for Sonos
also I can get the url from media_player.living_room.attributes.entity_picture
sensor.sonos_media
with a state :
/api/media_player_proxy/media_player.living_room?token=1124256fa1cae8e1be0c476c2ce881aaf523ff4cfeaba2b1866759033a944f8b&cache=d05f973fec3e2c7b
The token changes every time there is a new image cover
How do I get that url into the image option?
thanks in advance
ok let me elaborate:
-I have an entity called media_player.living_room_2
-One of its attributes is entity_picture
-The content of that attribute is a url with a token that changes depending on the art cover
This works all fine and dandy in the media-control type card, because it pulls the url on its own. But im setting up another Lovelace with HomeKit styled cards an the code goes as follows:
 - type: 'custom:mini-media-player'
                sync_volume: true
                entity: media_player.living_room
                image: >-
                  {{ state(media_player.living_room.attributes.entity_picture)
                speaker_group:
                  platform: sonos
                  show_group_count: true
                  artwork: full-cover
                  sync_volume: true
                  expanded: false
                  entities:
                    - entity_id: media_player.Living_Room
                    - entity_id: media_player.Living_Room_2
                      sync_volume: true
there in the image option lies the issue, its expecting a string and it works when its provided
What I want is to pass the attribute “entity_picture” instead of the string
Ihope this is clearer
The correct method to get a state out of an entity is states(), however you’re trying to get an attribute, which is state_attr().
Also, you need to wrap the entity_id in quotes as well as the attribute.
Thats the thing Petro, I have done all that and still nothing, check this out:
I’ve correctly templated this data into a sensor entity called sensor.sonos_media. And I can see its taking the url:
 sonos_media:
        friendly_name: "sonos_media"
        value_template: "{{ (state_attr('media_player.living_room', 'entity_picture')) }}"
I’ve also passed it the way I’ve stated and the way you have stated (the correct way), I’ve ALSO tried to pass the sensor “sensor.sonos_media” that has the url
like this
image: {{ states('sensor.sonos_media') }}
I get
                image:
                  '[object Object]': null
but it can’t be null because im seeing its value right nou in developer tools!
Screen Shot 2021-01-25 at 9.59.53 AM
This is the card:
Screen Shot 2021-01-25 at 10.01.08 AM
And when I get long press to go to the more info pop up, the image I want is there!!! OMG and can’t get it out!!!
Screen Shot 2021-01-25 at 10.01.13 AM
/api/media_player_proxy/… is not the full path and that’s most likely your issue.
When I hard code the value of the attribute or the templated sensor (see link) the picture works
See picture when I hard code url
Screen Shot 2021-01-25 at 10.09.48 AM
put the template in double quotes or use the multiline indicator > and move the template to the next line.
This
Screen Shot 2021-01-25 at 10.22.37 AM
turns into this after I save
Screen Shot 2021-01-25 at 10.23.20 AM
still no image
Please reread this
I don’t mean to be dense but even tho I didn’t provide a picture I also used the multilane indicator and got the same result.
when you say put the template on double quotes, did I do that right?
what would be the notation when I use the multiline indicator?
Thanks a lot for the help
No this is what a template wrapped in double quotes would look like:
image: "{{ states('sensor.sonos_media') }}"
I provided it already
image: >
Double quotes result in this
Screen Shot 2021-01-25 at 10.32.03 AM
Doesn’t work
(edit) Multiline turns into something else (sorry had an indentation issue before):
Screen Shot 2021-01-25 at 10.41.24 AM
What doesn’t work about the first image?
In the multiline indicator, the template needs to be indented by 2 spaces from image, like my example.
Result for both is no image
Screen Shot 2021-01-25 at 10.42.26 AM
instead of using that template to grab the state, just use the state_attr template in it instead, see if that works.
Ok I don’t know if this plays a role in the behavior im seeing, but all of this is wrapped in a fullscreen card add-on called home kit that makes rows and columns so I can organize mi view like so:
The code I use to prepare this Lovelace view is:
  - title: Tiles
    background: center / cover no-repeat fixed url("/local/bg2.jpg")
    path: Tiles
    panel: true
    icon: 'hass:tablet'
    style:
      opacity: 50
    badges: null
    cards:
      - type: 'custom:homekit-card'
        title: tablet
        style: |
          :host {
            font-family: -apple-system, BlinkMacSystemFont, sans-serif;
        useBrightness: false
        useTemperature: false
        tileHoldAnimation: true
        titleColor: '#FFF'
        enableColumns: true
        statePositionTop: true
        rows:
          - row: 1
            columns:
              - column: 1
                tileOnRow: 3
                entities:
I have no idea, I don’t use that card. Does that card support images?
Does that card support templates for any field?
Yes, in that little circle it has an option called image that receives a url as string and displays it there
What im beginning to think is it doesn’t play well with gettin a variable instead of the string.
