Thank you for your reply.
It parses okay now, but I get an error when it is executed:
2021-01-11 13:21:12 ERROR (MainThread) [homeassistant.components.automation.mini_lampen] Mini lampen: Choose at step 1: choice 1: Error executing script. Invalid data for call_service at pos 1: expected dict for dictionary value @ data['data']
2021-01-11 13:21:12 ERROR (MainThread) [homeassistant.components.automation.mini_lampen] Mini lampen: Error executing script. Invalid data for choose at pos 1: expected dict for dictionary value @ data['data']
2021-01-11 13:21:12 ERROR (MainThread) [homeassistant.components.automation.mini_lampen] While executing automation automation.mini_lampen
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 404, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1026, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 242, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 250, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 596, in _async_choose_step
await self._async_run_script(script)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 670, in _async_run_script
await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 419, in _async_run_long_action
long_task.result()
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 457, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1399, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 218, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 341, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 337, in _exec
v = func(v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: expected dict for dictionary value @ data['data']
I am migrating towards the deconz.configure service because that service provides a nicer flow towards new values (in transition) for some reason. So for example when my colour temperature is moving from ‘200’ to 400’ in 5 minutes at certain sun-events. (using the light.on service it sometimes ‘stutters’ towards the new values over time. My tests with using the deconz.configure give better results)
