HI, i’m trying to setup deep sleep.
My aim is to wake on deep sleep when a binary sensor (reed switch) goes open, then return to deep sleep when the binary sensor closes.
I have tested my binary sensor and know that it is working fine,
I’ve also tried with the touch component,
I also keep getting the error that my GPIO is used in two places.
Do I HAVE to have a separate wakeup pin source to wake from deep_sleep?
esphome:
friendly_name: test
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key:
ota:
password:
wifi:
networks:
- ssid: !secret wifi_ssid
fast_connect: true
captive_portal:
deep_sleep:
wakeup_pin: GPIO26
wakeup_pin_mode: INVERT_WAKEUP
binary_sensor:
- name: "my_binary"
platform: gpio
pin: GPIO26
filters:
invert:
on_release:
- deep_sleep.enter:
