Hi all, I’m really struggling with creating a template sensor to convert some of my soil moisture float sensor data into a plain text value. Long term, I’d like to turn this into a blueprint so I can easily apply it to each sensor, but with how much trouble I’m having now that has been pushed back lol.
Expected Behavior
I’d like to ingest the raw float value from my soil moisture sensor, and then turn create another plain text sensor that outputs a string value depending on how moist the soil is. I’d then like this outputted string to be accessible as a sensor value, so that I can use it in my Lovelace dashboards.
What’s happening
The code works within the Template section of the Developers tab, but it’s not accessible as a sensor once I create the automation. I only see the automation which runs it
What I think the problem is
I think this is an issue with how I’m declaring the sensor/template within automations.yaml. But no matter how many different ways I construct it I get the same result. I’m hoping someone can help clear up how I take a functioning value template from the Developer’s Tools and put it into production in a way where I can access it’s result as sensor.plain_text_snow_peas
for example
Technical Information And Scripts
Hass.io OS 5.13
supervisor-2021.04.3
core-2021.5.5
Value Template
{% set sat_level = states('sensor.soil_moisture_level_3') | float %}
{% if 0 < sat_level <= 20 %}
Bone Dry
{% elif 20.001 < sat_level <= 40 %}
Water Soon
{% elif 40.00 < sat_level <= 60 %}
Moderately Moist
{% elif 60.00 < sat_level <= 80 %}
Recently Watered
{% elif 80.00 < sat_level %}
Absolutely Soaked
{% else %}
Saturation Unknown
{% endif %}
automations.yaml
- id: '1618931435538'
alias: Printer Power Down
description: ''
- platform: state
entity_id: \binary_sensor.octoprint_printing
to: 'off'
for: 00:10:00
- type: turn_off
device_id: 0ca104bde9ea4742dd0315ca19c1bdba
entity_id: light.printing_overhead
domain: light
- type: turn_off
device_id: 9a1a35ba729ed97241114d6e1cd0ba10
entity_id: switch.closet_outlet_on_off
domain: switch
mode: single
- id: '1618932266889'
alias: Bar Lights Power
description: ''
use_blueprint:
path: EPMatt/ikea_e1743.yaml
input:
integration: ZHA
controller_device: 07b966807cd931790a7d548161e495dc
action_button_up_short:
- type: turn_on
device_id: bd4e9c7e7d4b87b5c8c9971d74c0f572
entity_id: light.breakfast_bar_light_1
domain: light
brightness_pct: 100
- type: turn_on
device_id: e88ced2964111c9b6c6ba2ee7f3ffb26
entity_id: light.breakfast_bar_light_2
domain: light
brightness_pct: 100
action_button_down_short:
- type: turn_off
domain: light
- type: turn_off
domain: light
- id: '1619218813557'
alias: Grow Lights On
description: ''
- platform: time
at: '6:00'
condition: []
- type: turn_on
device_id: 9243036911c8b618e6a5cc2e638679f2
entity_id: switch.space_heater
domain: switch
mode: single
- id: '1619218860127'
alias: Grow Lights Off
description: ''
- platform: time
at: '21:00'
condition: []
- type: turn_off
domain: switch
- type: turn_off
domain: light
mode: single
- id: '1620237100047'
alias: Don't kill the seeds!!
description: Get a notification if the seedlings get too hot
- platform: numeric_state
entity_id: sensor.greenhouse_ambient_temperature
above: '87'
condition: []
- device_id: 37b3fd255de7adbfff583974f229d271
domain: mobile_app
type: notify
title: Seedling Warning
message: Your seedling nursery has reached temperatures over 88 degrees!
mode: single
- id: '1620774165350'
alias: Water the plants downstairs
description: ''
entity_id: sensor.soil_moisture_level
below: '40'
condition: []
domain: mobile_app
type: notify
title: Water The Peas!
message: Your snow peas' soil just dropped below 40% saturation, it's probably
time to go check on the plants!
mode: single
- id: '1620785218157'
alias: Bar Light Switch
description: Control the bar lights without your voice
use_blueprint:
path: niro1987/zha_ikea_tradfri_2button_remote_brightness.yaml
input:
remote_ieee: 5c:02:72:ff:fe:94:91:71
light_entity: light.kitchen_lights
- id: '1621184064105'
alias: Keep Home Assistant Fresh
description: ''
- platform: time
at: 01:00:00
condition: []
- service: homeassistant.restart
mode: single
- id: '1622391156482'
alias: Snow Pea Soil State
description: Convert the raw snow pea soil state into a plain text description based
on 5 predefined buckets
value_template: "{% set sat_level = states('sensor.soil_moisture_level_3') | float\
\ %}\n\n {% if 0 < sat_level <= 20 %}\n Bone Dry\n \
\ {% elif 20.001 < sat_level <= 40 %}\n Water Soon\n \
\ {% elif 40.00 < sat_level <= 60 %}\n Moderately Moist\n \
\ {% elif 60.00 < sat_level <= 80 %}\n Recently Watered\n \
\ {% elif 80.00 < sat_level %}\n Absolutely Soaked\n \
\ {% else %}\n Saturation Unknown\n {% endif %}"
mode: single
