Hi!
I’ve been having some trouble figuring out how to configure my door close automation.
I have a handful of doors that I set up an alert letting me know if the door has been open for more than 5 minutes.
I’m trying to figure out a way to get a notification if a door that was open for more than 5 minutes was closed.
Here is my current door open notification.
alias: Door Open Notification
- platform: state
entity_id:
- binary_sensor.kitchen_garage_door
- binary_sensor.back_door
- binary_sensor.front_door
- binary_sensor.side_garage_door
for:
hours: 0
minutes: 5
seconds: 0
to: "on"
- service: notify.mobile_app
data_template:
title: Door Open Alert
message:
The {{ trigger.to_state.attributes.friendly_name }} has been open for
priority: high
You can use trigger variables to limit notification based on the length of time between now and that stored in the last_changed
property with an offset based on the open duration. The last_changed
property of the from_state
will hold a datetime object reflecting when the previous state change occurred. In this case we will use trigger ids to filter it so it only checks when the binary sensor in question turned “on”, then we add a 5 minute offset to that time and compare it to the current time.
description: ""
- platform: state
entity_id:
for: "00:05:00"
to: "on"
- platform: state
entity_id:
to: "off"
- choose:
- conditions:
- condition: trigger
sequence:
message:
priority: high
- conditions:
- condition: template
value_template: "{{ now() >= trigger.from_state.last_changed + timedelta(minutes=5) }}"
sequence:
title: Door Open Alert Resolved
message:
The {{ trigger.to_state.attributes.friendly_name }} has been closed.
priority: high
This could be condensed even further using a few more templates to eliminate the Choose action.
Thank you @Didgeridrew that worked perfectly. You’ve saved my sanity!
