I am trying to understand the correct way to use a zwave door sensor. eventually i want to build an alarm panel like here:
I have a zwave wadwaz-1 sensor, i am not sure what entities should i be using from below i see 6 entries for this node.
sensor.alarm_level State: 255
Attributes:
node_id: 18
value_index: 1
unit_of_measurement:
value_id: 72057594345963537
old_entity_id: sensor.alarm_level_18_1
value_instance: 1
new_entity_id: sensor.alarm_level
friendly_name: Alarm Level
sensor.alarm_type State:7
Attributes:
ode_id: 18
value_index: 0
value_id: 72057594345963521
old_entity_id: sensor.alarm_type_18_0
value_instance: 1
new_entity_id: sensor.alarm_type
friendly_name: Alarm Type
sensor.linear_unknown_type2001_id0102_burglar
State: 3
Attributes:
node_id: 18
value_index: 10
value_id: 72057594345963681
old_entity_id: sensor.linear_unknown_type2001_id0102_burglar_18_10
value_instance: 1
new_entity_id: sensor.linear_unknown_type2001_id0102_burglar
friendly_name: Linear Unknown: type=2001, id=0102 Burglar
sensor.linear_unknown_type2001_id0102_sourcenodeid
State: 0
Attributes:
node_id: 18
value_index: 2
value_id: 72057594345963553
old_entity_id: sensor.linear_unknown_type2001_id0102_sourcenodeid_18_2
value_instance: 1
new_entity_id: sensor.linear_unknown_type2001_id0102_sourcenodeid
friendly_name: Linear Unknown: type=2001, id=0102 SourceNodeId
binary_sensor.sensor
State:on
Atributes:
node_id: 18
value_index: 0
value_id: 72057594344898560
old_entity_id: binary_sensor.sensor_18_0
value_instance: 1
new_entity_id: binary_sensor.sensor
friendly_name: Sensor
zwave.__2
State:Sleeping
Attributes:
receivedCnt: 39
battery_level: 100
node_name:
product_name:
is_zwave_plus: false
lastRequestRTT: 79
receivedDups: 0
query_stage: Complete
friendly_name:
is_failed: false
is_awake: false
manufacturer_name:
is_info_received: true
averageResponseRTT: 35
neighbors: 1,2,5,11,12,16,17
new_entity_id: zwave._
lastResponseRTT: 35
wake_up_interval: 3600
sentCnt: 22
receivedTS: 2017-10-13 00:31:08:476
capabilities: beaming,routing
sentFailed: 0
receivedUnsolicited: 25
node_id: 18
is_ready: true
old_entity_id: zwave.__18
averageRequestRTT: 52
sentTS: 2017-10-13 00:22:53:702
retries: 0
max_baud_rate: 40000
thanks,
