hey all
i have recently installed the double take addon in home assistant but am having trouble with it connecting to frigate it works but the frigare connection geeps flashing/ shows solid grey and i have no idea how to fix it here is the logs if it is any help
camera: 'front_door',
zones: [],
counts: { person: 0, match: 0, miss: 0, unknown: 0 },
matches: [],
misses: [],
unknowns: []
24-02-01 13:49:30 error: Error: frigate status error: timeout of 5000ms exceeded
at Object.module.exports.checks (/double-take/api/src/util/frigate.util.js:79:11)
at runMicrotasks (<anonymous>)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async module.exports.start (/double-take/api/src/controllers/recognize.controller.js:85:21)
24-02-01 13:49:37 info: processing doorbell: 0f810ff5-8b80-46a0-b010-33fa7b82edfa
24-02-01 13:49:37 info: done processing doorbell: 0f810ff5-8b80-46a0-b010-33fa7b82edfa in 0.21 sec
24-02-01 13:49:37 info: {
duration: 0.21,
timestamp: '2024-02-01T13:49:37.454Z',
attempts: 1,
camera: 'doorbell',
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 13:49:42 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 13:49:45 info: processing doorbell: db7b0457-a7a8-4b85-a591-7921c9916107
24-02-01 13:49:45 info: done processing doorbell: db7b0457-a7a8-4b85-a591-7921c9916107 in 0.22 sec
24-02-01 13:49:45 info: {
duration: 0.22,
timestamp: '2024-02-01T13:49:45.903Z',
attempts: 1,
camera: 'doorbell',
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 13:49:47 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 13:57:20 info: processing doorbell: dbf76e60-b040-4f4f-bb35-7fa298771782
24-02-01 13:57:21 info: done processing doorbell: dbf76e60-b040-4f4f-bb35-7fa298771782 in 0.21 sec
24-02-01 13:57:21 info: {
duration: 0.21,
timestamp: '2024-02-01T13:57:21.193Z',
attempts: 1,
camera: 'doorbell',
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 13:57:25 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 13:57:26 info: processing doorbell: d1db739e-883f-4ff6-810b-b64d546f4e22
24-02-01 13:57:27 info: done processing doorbell: d1db739e-883f-4ff6-810b-b64d546f4e22 in 0.26 sec
24-02-01 13:57:27 info: {
duration: 0.26,
timestamp: '2024-02-01T13:57:27.003Z',
attempts: 1,
camera: 'doorbell',
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 13:57:31 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 14:30:18 info: processing doorbell: 790a749d-0ca1-40c9-9462-822a7dd81d9c
24-02-01 14:30:18 info: done processing doorbell: 790a749d-0ca1-40c9-9462-822a7dd81d9c in 0.2 sec
24-02-01 14:30:18 info: {
duration: 0.2,
timestamp: '2024-02-01T14:30:18.827Z',
attempts: 1,
camera: 'doorbell',
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 14:30:23 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 14:30:28 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 14:30:34 info: processing doorbell: 7b4d8872-8381-4f75-8716-3e2aa82984d2
24-02-01 14:30:34 info: done processing doorbell: 7b4d8872-8381-4f75-8716-3e2aa82984d2 in 0.21 sec
24-02-01 14:30:34 info: {
duration: 0.21,
timestamp: '2024-02-01T14:30:34.353Z',
attempts: 1,
camera: 'doorbell',
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 16:17:34 info: processing front_door: b3fa9fc0-ea60-4db1-91a2-75f405f7a4ea
24-02-01 16:17:34 info: done processing front_door: b3fa9fc0-ea60-4db1-91a2-75f405f7a4ea in 0.32 sec
24-02-01 16:17:34 info: {
duration: 0.32,
timestamp: '2024-02-01T16:17:34.815Z',
attempts: 1,
zones: [],
counts: { person: 1, match: 1, miss: 0, unknown: 0 },
matches: [
confidence: 99.71,
match: true,
box: [Object],
type: 'mqtt',
duration: 0.31,
detector: 'compreface',
filename: '08aadf3a-cbc2-4cda-8af6-7ebec5124e0c.jpg'
misses: [],
unknowns: []
24-02-01 16:17:39 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:17:40 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:17:43 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:17:44 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:17:46 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:17:59 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:18:01 error: Error: frigate status error: socket hang up
24-02-01 16:18:06 info: processing front_door: dcdeff09-31ca-49f3-a805-cb1e5dfb5513
24-02-01 16:18:06 info: done processing front_door: dcdeff09-31ca-49f3-a805-cb1e5dfb5513 in 0.2 sec
24-02-01 16:18:06 info: {
duration: 0.2,
timestamp: '2024-02-01T16:18:06.931Z',
attempts: 1,
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 16:24:56 info: processing front_door: d8637756-2950-49f3-b524-b1c17bd51a10
24-02-01 16:24:56 info: done processing front_door: d8637756-2950-49f3-b524-b1c17bd51a10 in 0.23 sec
24-02-01 16:24:56 info: {
duration: 0.23,
timestamp: '2024-02-01T16:24:56.495Z',
attempts: 1,
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 16:25:01 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:25:23 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:25:51 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:25:52 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:26:07 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:26:22 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:26:25 error: Error: frigate status error: socket hang up
24-02-01 16:26:51 info: processing front_door: 4fdd44ea-0f55-4ee9-851f-9583f2057d47
24-02-01 16:26:51 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:26:52 info: done processing front_door: 4fdd44ea-0f55-4ee9-851f-9583f2057d47 in 0.23 sec
24-02-01 16:26:52 info: {
duration: 0.23,
timestamp: '2024-02-01T16:26:52.072Z',
attempts: 1,
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 16:26:56 error: Error: frigate status error: timeout of 5000ms exceeded
at runNextTicks (node:internal/process/task_queues:65:3)
at listOnTimeout (node:internal/timers:528:9)
at processTimers (node:internal/timers:502:7)
24-02-01 16:26:57 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:27:03 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:27:08 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:27:13 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 16:27:17 info: processing front_door: 1cc74146-0096-4417-b25c-a07861913db0
24-02-01 16:27:17 info: done processing front_door: 1cc74146-0096-4417-b25c-a07861913db0 in 0.22 sec
24-02-01 16:27:17 info: {
duration: 0.22,
timestamp: '2024-02-01T16:27:17.993Z',
attempts: 1,
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 16:32:00 info: purged 2 file(s)
24-02-01 17:25:51 info: Double Take v1.13.1-8e2728d
24-02-01 17:25:53 info: MQTT: connected
24-02-01 17:25:53 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-02-01 17:27:05 info: Double Take v1.13.1-8e2728d
24-02-01 17:27:06 info: MQTT: connected
24-02-01 17:27:06 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-02-01 18:28:59 info: brian: queuing 1 file(s) for training
24-02-01 18:28:59 info: brian: training complete in 1.3 sec
24-02-01 19:30:44 info: processing front_door: 5970b11f-ccdc-4ae4-894e-8c6b3bc8a02e
24-02-01 19:30:44 info: done processing front_door: 5970b11f-ccdc-4ae4-894e-8c6b3bc8a02e in 0.18 sec
24-02-01 19:30:44 info: {
duration: 0.18,
timestamp: '2024-02-01T19:30:44.450Z',
attempts: 1,
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 19:30:49 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 19:30:54 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 19:31:11 info: processing front_door: ccc84338-884c-44eb-bdc0-34539778f81f
24-02-01 19:31:12 info: done processing front_door: ccc84338-884c-44eb-bdc0-34539778f81f in 0.24 sec
24-02-01 19:31:12 info: {
duration: 0.24,
timestamp: '2024-02-01T19:31:12.149Z',
attempts: 1,
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 20:24:40 info: processing front_door: 636df66b-8cdf-4a2c-93c1-1865e5727b3f
24-02-01 20:24:41 info: done processing front_door: 636df66b-8cdf-4a2c-93c1-1865e5727b3f in 0.18 sec
24-02-01 20:24:41 info: {
duration: 0.18,
timestamp: '2024-02-01T20:24:41.152Z',
attempts: 1,
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 20:24:45 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 20:25:29 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 20:26:07 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 20:37:01 info: processing front_door: 68468f9e-e1f5-431a-8b50-dec63fa49292
24-02-01 20:37:01 info: done processing front_door: 68468f9e-e1f5-431a-8b50-dec63fa49292 in 0.18 sec
24-02-01 20:37:01 info: {
duration: 0.18,
timestamp: '2024-02-01T20:37:01.369Z',
attempts: 1,
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 20:37:06 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 22:56:57 info: processing front_door: 78c57b14-cb84-447d-a2a3-4447ffb5c1c7
24-02-01 22:56:58 info: done processing front_door: 78c57b14-cb84-447d-a2a3-4447ffb5c1c7 in 0.18 sec
24-02-01 22:56:58 info: {
duration: 0.18,
timestamp: '2024-02-01T22:56:58.152Z',
attempts: 1,
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 22:57:02 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-01 23:19:19 info: processing front_door: 3a080111-8b39-45aa-9936-38f263216b75
24-02-01 23:19:19 info: done processing front_door: 3a080111-8b39-45aa-9936-38f263216b75 in 0.24 sec
24-02-01 23:19:19 info: {
duration: 0.24,
timestamp: '2024-02-01T23:19:19.426Z',
attempts: 1,
zones: [],
matches: [],
misses: [],
unknowns: []
24-02-01 23:19:24 error: Error: frigate status error: timeout of 5000ms exceeded
24-02-02 00:01:43 info: Double Take v1.13.1-8e2728d
24-02-02 00:01:45 info: MQTT: connected
24-02-02 00:01:45 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-02-02 00:22:46 info: Double Take v1.13.1-8e2728d
24-02-02 00:22:48 info: MQTT: connected
24-02-02 00:22:48 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-02-02 00:24:00 info: Double Take v1.13.1-8e2728d
24-02-02 00:24:01 info: MQTT: connected
24-02-02 00:24:01 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-02-02 00:26:17 info: Double Take v1.13.1-8e2728d
24-02-02 00:26:19 info: MQTT: connected
24-02-02 00:26:19 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
any help is appreciated
