Help with draft of blueprint for managing ceiling and room lights
I’m working on a blueprint to turn off room lights if ceiling light is swiched on (saving status and attributes) and restore status when ceiling light is swiched off.
Here’s what I achieved so far:
blueprint:
  name: Inverse sync Ceiling vs Secondary Lights
  description: Turn off room lights if ceiling light is swiched on (saving status and attributes) and restore status when ceiling light is swiched off.
  domain: automation
  input:
    ceiling_light:
      description: This is the Ceiling light, will be turned on when the secondary light is turned on.
      selector:
        entity:
          domain: light
    room_light_1:
      name: Room light 1
      description: This is the secondary light, will be turned off when the ceiling light is turned on.
      selector:
        entity:
          domain: light
    room_light_2:
      name: Room light 2
      selector:
        entity:
          domain: light
    scene_name:
      description: Name of the scene that will storage attributes of the room lights
      selector:
        entity:
          domain: input_text
variables:
  scene_entity: !input 'scene_name'
  - platform: state
    entity_id: !input ceiling_light
    to: "on"
  - platform: state
    to: "off"
  choose:
    - conditions:
        - condition: template
          value_template: "{{ trigger.to_state.state == 'on' }}"
      sequence:
        - service: scene.create
            scene_id: !input scene_entity
            snapshot_entities:
              - !input room_light_1
              - !input room_light_2
        - service: light.turn_off
            entity_id:
    - conditions:
          value_template: "{{ trigger.to_state.state == 'off' }}"
      sequence:
        - service: scene.turn_on
            entity_id: scene.xxxx
  default: []
How can I change scene.xxxx with scene name in !input ‘scene_name’?
Thank you in advance!
I do not have the solution for you, but may be a hint.
In normal automation one can you something like
service_template: input_boolean.turn_{{ states('switch.workstation') }}
data: {}
entity_id: input_boolean.workstation
may-be you can adopt it for your bluepint in a similar way
i.e. (dont know if and how correctly to implement)
            entity_id: scene.{{here-scene-name of scene}}
I made some change but 2nd choise does not work:
blueprint:
  domain: automation
  input:
    ceiling_light:
      selector:
        entity:
          domain: light
    room_light_1:
      name: Room light 1
      selector:
        entity:
          domain: light
    room_light_2:
      name: Room light 2
      selector:
        entity:
          domain: light
    scene_name:
      selector:
        text:
  - platform: state
    to: "on"
  - platform: state
    to: "off"
  choose:
    - conditions:
      sequence:
            scene_id: !input scene_name
            snapshot_entities:
            entity_id:
    - conditions:
      sequence:
            entity_id: !input scene_name
  default: []
there’s something in the scene…
Error while executing automation automation.inverse_sync_ceiling_vs_secondary_lights: not a valid value for dictionary value @ data[‘entity_id’]
  • Studio - Luce Soffitto Test: Choose at step 1: choice 2: Error executing script. Invalid data for call_service at pos 1: not a valid value for dictionary value @ data[‘entity_id’]
  • Studio - Luce Soffitto Test: Error executing script. Invalid data for choose at pos 1: not a valid value for dictionary value @ data[‘entity_id’]
your scene_name is text and not a entity. This will not work.
I’ve tested it: My solution works! (“data” → “target” in your case)
blueprint:
  domain: automation
  input:
    scene_name:
      selector:
        text:
mode: queued
variables:
   scene_name: !input scene_name
  - platform: time
    at: '11:45:00'
    #- service: scene.turn_on
    #  data:
    #    entity_id: scene.{{ state_attr(scene_name, 'friendly_name') }}
        entity_id: scene.{{scene_name}}
Remember: you have to use the internal name of your scene in input-text, not the “friendly_name”.
I didnt get your idea in details, but if you want to store the state of entities, you have probably to use “create” for scens and then, somehow to reload them.
Thank you!
now it works:
For all the curious out there
blueprint:
  domain: automation
  input:
    ceiling_light:
      selector:
        entity:
          domain: light
    room_light_1:
      name: Room light 1
      selector:
        entity:
          domain: light
    room_light_2:
      name: Room light 2
      selector:
        entity:
          domain: light
    scene_name:
      selector:
        text:
variables:
  - platform: state
    to: "on"
  - platform: state
    to: "off"
  choose:
    - conditions:
      sequence:
            snapshot_entities:
            entity_id:
    - conditions:
      sequence:
  default: []
I want to make blueprint more flexible so now you can have one of multiple secondary lights.
The issue is on the scene.create part. I doesn’t work anymore:
blueprint:
  name: Marco - Inverse sync Ceiling vs Secondary Lights
  domain: automation
  input:
    ceiling_light:
      default: {}
      selector:
        entity:
          domain: light
    room_light:
      default: {}
      selector:
        entity:
          multiple: true
          domain: light
    scene_name:
      selector:
        text:
    boolean_name:
      description: Name of the room in which are the lights
      default: false
      selector:
        text:
variables:
  boolean_name: !input boolean_name
  - platform: state
    to: "on"
  - platform: state
    to: "off"
  choose:
    - conditions:
      sequence:
            snapshot_entities:
              - !input room_light
            entity_id:
              - !input room_light
    - conditions:
          value_template: "{{ is_state('input_boolean.' + boolean_name, 'off') }}"
      sequence:
  default: []
Error says :
 Error while executing automation automation.gestione_luci_studio: value should be a string for dictionary value @ data['snapshot_entities']
can you please help me? Thank you
