Try with 2.2k or even 1k pullups.
Strange anyway, I would expect errors instead wrong temperature…
Did you look at the log? Maybe it’s not updating sensor values because of errors…
[00:57:53][D][dallas.temp.sensor:054]: 'Fridge Tempreature': Got Temperature=-5.9°C
[00:57:53][D][sensor:093]: 'Fridge Tempreature': Sending state -5.87500 °C with 1 decimals of accuracy
[00:58:00][D][dallas.temp.sensor:054]: 'Freezer Tempreature': Got Temperature=-3.4°C
[00:58:00][D][sensor:093]: 'Freezer Tempreature': Sending state -3.37500 °C with 1 decimals of accuracy
Swap the sensors and see how it looks like.
Note that you can’t locate the sensor in fridge to the body, there has to be good air cap between.
If your beers are getting frozen in fridge, you are confirmed.
