Hi Folks,
I am having trouble getting together a card that will serve as a notification for certain events that could result from changes in zero, one or multiple entities meeting certain criteria:
- If no entities match the criteria, the card should not show.
- In the event that a single entity meets the criteria, I want the warning card to show the specific entity with the issue.
- In the event of multiple, it should display a aggregate message, for example “3 doors are opened”.
Working example (WIP from a design/look POV):
I have a almost working example, but even though it looks like it works, I get continuous javascript errors in the console. It looks like the template-card
is assuming the entities are a template. The javascript error is:
Uncaught (in promise) TypeError: template.includes is not a function
_evaluateTemplate config-template-card.js:883
The lines near the code that cause the error:
evaluateTemplate(template) {
if (!template.includes('${')) {
return template;
Debugging the above error, it shows that the entities
I pass in as a list is getting into this code-flow. Obviously the sensor entity does not have an includes
method, which is why the error shows up.
Below is my current relevant lovelace config for the de-clutter template and button-card templates. A key thing to point out, in case it’s not obvious, I always want either a single card or no card showing up, regardless of how many entities are in the category. Some example of what I want to use this card for are: “Door locks with less than X% battery”, “Open doors greater than 5 mins”, etc.
OK, my config that is working functionally, but has errors in the console is:
decluttering_templates:
notify_card:
default:
- card_color_hex: '#FF8A65'
- title: My notification
card:
type: entity-filter
state_filter:
- operator: '[[filter_op]]'
value: '[[filter_value]]'
entities: '[[entities]]'
show_header_toggle: false
show_empty: false
card:
type: custom:config-template-card
variables:
entity_cnt: |
_ => {
return this.___config.entities.length;
button_template: |
_ => {
let entity_cnt = this.___config.entities.length;
return entity_cnt == 1 ? 'notify_single_entity' : 'notify_multiple_count';
entity: |
_ => {
return this.___config.entities[0].entity;
card:
type: custom:button-card
entity: ${ entity() }
template: ${ button_template() }
label: '[[title]]'
variables:
card_color: '[[card_color_hex]]'
name_regex_remove: '[[name_regex_remove]]'
button_card_templates:
base_notify:
variables:
bg_hex_opacity: dd
color: '#ff9d0a'
show_state: true
show_label: true
styles:
name:
- color: white
state:
- color: white
icon:
- color: white
label:
- font-weight: 500
- font-size: 22px
card:
- background-color: '[[[ return variables.card_color + variables.bg_hex_opacity ]]]'
- border-radius: 10px
- '--mdc-ripple-color': whitesmoke
notify_single_entity:
template:
- base_notify
let name = entity.attributes.friendly_name;
if (variables.name_regex_remove) {
name = name.replace(new RegExp(variables.name_regex_remove, 'i'), '');
return name;
styles:
grid:
- grid-template-areas: |
"i s"
"n n"
"l l"
- grid-template-columns: 1fr 1fr
- grid-template-rows: 1fr 1fr
icon:
- width: 34px
state:
- font-weight: 500
name:
- font-size: 14px
And example card instance using above template:
type: custom:decluttering-card
template: notify_card
variables:
- filter_op: <=
- filter_value: '60'
- title: Low Battery
- name_regex_remove: \\s*Battery level
- entities:
- sensor.garage_door_battery_level
- sensor.backdoor_battery_level
- sensor.frontdoor_battery_level
- sensor.laundry_door_battery_level
Some other notes:
- This seems to work with no errors–if I don’t use decluttering templates–but obviously I want many of these possible warning cards to show up, so am looking to be as DRY as possible.
- I have tried using
auto-entities
instead ofentity-filter
, but get the same error. - I am aware that the documentation doesn’t really suggest that the
declutter-card
supports arrays, but it does seem to work pretty close (besides the code somehow thinking the entities are templates). - As I said, the card works functionally - but I am very wary of having this error show up on every entity update in the console.
